Hi guys i just picked up a 05 sv6 with 80k on the clock and have noticed a few noises that i'm worried about. The fist one is coming from the intake manifold/injector area and kind of sounds like noisy injectors, it actually sounds like a diesel at idle.
The second sound happens if i'm sitting still in park and i give the throttle a quick short blurt, this makes a loud tinny sound like the throttle body opening with a metal on metal sound. Any help would be great. Cheers
I have heard people talk of loose heat shields on the exhaust manifolds making a noise.
Haven't had the problem on mine, but it might be worth checking.
Cheers,
Gary
PS: Torana man are you? Me too!
the second noise your talking about, is that heard after you release the throttle after a quick rev, if so thats the variable intake opening and closing, nothing to worry about
Does anyone else know if the injectors are meant to make a slight ticking noise??
the variable intake, is just basicly flaps inside the intake manifold, that increase/decrease the lenght of the manifold. the noise your hearing is the flaps reseating into there normal postion
mate you will find that the ticking noise is a little solenoid that is located under the passenger side engine cover.. it is a purge solenoid for the charcoal canister
just to set it straight it is completely normal and nothing to worry about
EASTERN CREEK JCNSW 2009
Originally Posted by Commydoor
Cheers everyone![]()
