Page 1 of 3 123 LastLast
Results 1 to 25 of 66
Thread: Just got my VCM tune done at CHE
    05 VZ SV6 With VCM tune by CHE
    Mar 2009
    Default Just got my VCM tune done at CHE
    Well i just got my tune done today and was very happy with the work that Dale did. I was a little unhappy that my SV6 only managed 167rwhp standard but with a end result of 192rwhp i was very happy with the gains. 25hp gain!!
    On the road the biggest difference is the off the line torque that is now available, only a fraction of throttle and it pulls hard off the line. The 0-100 time seems very similar but the changes are alot more aggressive like a shift kit has been put in (5 speed auto). Up high it does rev a little bit quicker but nothing major, the midrange though is very good now. Over all it makes for a good cruiser with a little more poke off the line. Will report back after i do a fuel consumption comparison.
    andyman's Avatar
    andyman is offline The Only 6sp VZ Wagon
    2012 BT50 4x4, 84 Hilux 4x4 & 05 Husky TE450
    Mar 2005
    Nowra, NSW
    Quote Originally Posted by torana355 View Post
    glad you like it, ive got vcm suite myself, its a very good program to use, im currently making a tune for my car and a vx ls1, just on my car, the improvements are huge, last night i finished off transmission and have started on engine, im lov'in it
    EASTERN CREEK JCNSW 2009
    Quote Originally Posted by Commydoor
    First of all your words cannot harm me cause my ego is like a shield of steel.
    Mar 2009
    Yeah im happy with the gains but i think i need to get a compression test done as 167rwhp standard is quite low as it should be about 190.... Though Dale did say the alloytec's are hit and miss and he has seen plenty of sv6's only pull 150rwhp stock.
    Ve Calais V 6ltr
    Sep 2007
    ADELAIDE
    whats this sort of tune worth? im keen to get one done also
    Mar 2009
    $880 includes before and after dyno printouts. Well worth the money if you want down low driveablity and better fuel consumption. Just don't expect it to turn into a v8 lol.
    Ve Calais V 6ltr
    Sep 2007
    ADELAIDE
    lol yeah man i know i was gonna get a tune before but decided to get a zorst and extractors for the same price but now i want a tune for better performance lol, thanxs for the info man
    andyman's Avatar
    Mar 2005
    Nowra, NSW
    that sounds about right, remember the 190 is at the flywheel, not the wheels as it was tested
    Mar 2009
    yeah i know but RWHP is usually the equivalent to FWKW. This means if the engine puts out 190kw at the flywheel it should have 190rwhp.
    PaulSV6's Avatar
    PaulSV6 is offline CHE Tuned 156.8rwkw
    VZ SV6 M6, MY10 VE SV6 Sportswagon & MY03 XC SRI
    Jun 2008
    Castle Hill
    I'll be interested in this as i just work around the corner from CHE & $880 isnt to bad.
    How long does it take?
    The Blue One
    Quote Originally Posted by buddaboy1990 View Post
    bahahaha i thought u meant an actual turtle shell.... im such an idiot....
    Quote Originally Posted by STEALTHY™ View Post
    Quoted for truth
    Mar 2009
    Well i got there at 8.30am and was out the door by 10.30am. It could take a little longer depending on how busy they are i guess.
    After driving the car a little more in Active select mode i am even more impressed!!, it is revving out quicker right though the range and when i launch it off from a standing start it squats down spins both wheels for a moment off she goes. Sooo much more torque down low :P Now i just have to stop having fun and see how fuel consumption is affected as the car was sitting at about 13.5:1 stock though Dale richened it up to 13:1 right across the rev range under full acceleration. Im guessing he leaned it out under light throttle loads???
    BullittSV6's Avatar
    BullittSV6 is offline Donating Member
    2005 VZ Commodore SV6
    May 2008
    Adelaide, South Australia
    The tune you got, did that include disabling torque management?
    andyman's Avatar
    Mar 2005
    Nowra, NSW
    Quote Originally Posted by BullittSV6 View Post
    usually yes they do, this is where probably half the gain comes from
    VZ Skaife Senator & VY SS UTE
    Jun 2004
    i'd say torque management is mostly gone if he's noticing lots more low end torque. don't stress about your power figure mate. i saw an sv6 with full exhaust pacies hi flow cats and catback with a growler intake only make 196rwhp once dale had finished tuning it. then there is lucky ones like me that make 197rwhp on dales dyno but i have a ve and they just seem to be alot more consistant with the power. though the down side of a ve is i can't get it tuned cause vcm wont update the bloody software.......
    Mar 2009
    Yep torque management is gooone. The engine can rev to redline in neutral and the car is able to do
    Anyway i just got back from a 100km round trip on the M4 and averaged 8.9l/100km including stop start traffic from my house to the M4 and some traffic in emuplains. Im guessing if i reset the trip meter on the highway it would have got down to very low 8's or even high 7's
    Yeah Dale did say the Alloytecs were very Hit and Miss and that plenty have gotten even lower power then mine. The main thing is the gains were exactly as claimed!!
  15. #15
    Jun 2004
  16. #16
    Mar 2009
    Stock as a rock. Even a Standard air filter. Not planning on an exhaust as im kind of over loud exhausts as ive had them all my life. Im still interested if Dale played around with the cruising settings like the half throttle and 1/4 throttle fuel mixtures/ timing ect. I will have to give him a ring on Monday and find out.
  17. #17
    Mar 2009
    Ok here is the before and after. As you can see i gained over 40hp in parts of the midrange. Im assuming 13:1 is a good Air/Fuel ratio?
  18. #18
    VZ
    Feb 2007
  19. #19
    Jun 2004
    thats actually a great result mate. get some pacemaker extractors and put a k&n in the airbox and it will make 200rwhp and wont be any louder.
  20. #20
    Jun 2004
    it would be about the same overall gain just a lower start and finish figure.
    Quote Originally Posted by HUMBLZ View Post
    looks good!anyone with results from the 175?
  21. #21
    Mar 2009
    Quote Originally Posted by monaro327 View Post
    Well my car was actually putting out the same power as a healthy 175 motor so the results i got would be the same as a 175kw motor putting out its claimed power. If my car was putting out 190rwhp stock like it should i would have ended up at closer to 210rwhp. Stupid underpowered lemon lol.
    Yeah i may get some pacemakers in the near future and will definitely get a k&n filter tomorrow. My cousin just took the car for a spin while i was sitting in the passo and it had me firmly planted in the seat from 60km to 140 on a private road. Im more happy with it the more i drive it!!
  22. #22
    Jun 2004
    thats good mate another worth while mod for the autos is 3.45 ratio diff.
  23. #23
    Mar 2009
    Don't tempt me lol. This car was meant to stay standard to stop me from losing my license again. Im at that age (28) where im starting to grow up and realize that cars are not all about speeding around that comfort and build quality are starting to grow as my priority's. I think the K&N and perhaps some extractors if Castle hill exhaust tell me its worth the money for the gain will be as far as i will go. I want to keep the diff ratio standard for fuel economy.
  24. #24
    Jun 2004
  25. #25
    Mar 2009
    no worries mate dave and dale will look after you.
    haha all good i can just see myself going all out and ending up with a raptor charger kit if i don't keep a lid on the mods. Cant deal with the anymore
  1. Maf tune vs Mafless tune
    By Senator Slash in forum VY Holden Commodore (2002 - 2004)
    Last Post: 01-02-2009, 09:25 AM
  2. Help tune
    By el-guanaco in forum LSx Development and Modification
    Last Post: 06-01-2009, 12:28 PM
  3. Do I need a re-tune/flash tune
    By Lowclubby in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 17-12-2008, 02:03 PM
  4. Tune
    By statey27 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 08-11-2005, 05:39 PM
  5. tune up
    By bigazza in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 31-10-2005, 03:33 PM
