My vz laggs b4 changing gears...Like id drive and it should change but revs and then changes...Whats the problem?
Thnx.
VR EXECUTIVE
We had some good times
More info??? does it rev out then slip for a while then change gear or does it just rev out to high revs before changing?
Maybe fluid is low? Check your levels.
Yeah get the fluids quality and levels checked. If it still does it you are best to take it to a mechanic.
The Blue One
