Results 1 to 6 of 6
Thread: Not key prob... Starter motor??
    vz
    Apr 2009
    Default Not key prob... Starter motor??
    Hey
    Just wondering if anyone has had a problem with starter motors etc with VZ models. Had a Locksmith look at it thinking it was the key sensor and $184 later he told me it must be the starter motor or relay because the key is ok.
    The problem is the car wont turn over at all (dead) but on a very rare occasion it will start. Battery is fine.
    Anyone with similar problems or advise out there.
    Thanks in advance for reading
    andyman's Avatar
    andyman is offline The Only 6sp VZ Wagon
    2012 BT50 4x4, 84 Hilux 4x4 & 05 Husky TE450
    Mar 2005
    Nowra, NSW
    Quote Originally Posted by ninjasan1 View Post
    Hey
    if you go to the starter relay and bridge terminals 86 and 30 does the engine crank normally? if you do this have the ignition on, it should start the motor
    EASTERN CREEK JCNSW 2009
    Quote Originally Posted by Commydoor
    First of all your words cannot harm me cause my ego is like a shield of steel.
    vz
    Apr 2009
    Quote Originally Posted by andyman View Post
    Ok I'll try that and see what happens, cheers.
    vz
    Apr 2009
    Hey, yeah I tried bridging 30 and 86...absolutely nothing, dead.
    On the "System Check" it says "Very Low Fuel...Service Vehicle Soon...Fuel Gauge Error" so I put 20 litres of fuel in and pulled out the ECM 10 amp fuse to see if the system would reset and tried again. No change.
    The engine must be immobilized due to the fuel gauge error. Does anyone know how to fix this?
    Thanks again
    andyman's Avatar
    Mar 2005
    Nowra, NSW
    Thanks again
    ah ok yep, it wont start because of that then, i take it you have disconnected the battery for 10min or so and re try it?
    get some one with a scan tool to pop around and see what error codes it spitting out
    vz
    Apr 2009
    Ok mate I guess I have to admit defeat and call someone... yeah I did have the battery disconnected for a while.
    Thanks for your help, keep the good work up ;p
  1. [SA] Wtb: vn v8 starter motor
    By shy304 in forum Swap / Wanted to Buy / Trade
    Last Post: 22-12-2008, 05:53 PM
  2. vn-vs v8 starter motor
    By vnv8driver in forum Parts And Other Items For Sale
    Last Post: 20-10-2008, 03:49 PM
  3. will a manual box starter motor fit on a auto box motor?
    By lil_oneblue in forum VL Holden Commodore (1986 - 1988)
    Last Post: 03-09-2007, 05:17 PM
  4. Is this my starter motor?
    By dave.b in forum VL Holden Commodore (1986 - 1988)
    Last Post: 18-09-2006, 08:42 PM
  5. Starter motor
    By Starion in forum Electrical Wiring / Questions
    Last Post: 27-10-2005, 06:39 PM
