Results 1 to 10 of 10
Thread: Would a 190 alloytech fit in a vz executive??
    vz bt1
    Dec 2008
    Default Would a 190 alloytech fit in a vz executive??
    hey guys, just wondering if a 190 alloytech motor and manual gearbox would fit right in a vz executive ... would i need to change anything or is it all pretty much the same .. thanks.
    shozzy's Avatar
    shozzy is offline "Licked by janitor"
    VZ executive 3.6
    Aug 2008
    Kallangur, QLD
    aren't they pretty much like the exact same engine apart from the executive has only got variable intake on one side of engine, where as the 190 is on both sides... im more than likely wrong but i think i remember reading that somewhere
    Go for gold, if not gold go for bronze, it's golder than silver
    pjdm1980's Avatar
    Feb 2009
    Geelong, Victoria
    It should bolt in but i would think it uses a different computer as the 190 has variable intake and exhaust valve timing and the 175 only has variable intake valve timing and should have same gearbox bolt pattern
    vz bt1
    Dec 2008
    hrmmm because i wanted to convert mine to a manual but its abit pricey still and i thought it would be better if the motor was originally manual, it would run better i think .. and would be easier to put in .. old out, new in if it fits plus its a 190 ..
    still just finding info on it
    07 SVZ Ute/A5 & 06 XR6T A6
    Aug 2007
    I wouldnt even bother,the 190 is not a power house. I drive the 175 in an exec. at work and i can honestly say i can not tell any diff between my 190 ute
    Glenn
    Ill show you that im Australian if you show me your brazilian.
    "I don't try to explain to people why I ride a Motorcycle. For those who understand no explanation is needed! For those who don't understand, no explanation is possible..."
    andyman's Avatar
    andyman is offline The Only 6sp VZ Wagon
    2012 BT50 4x4, 84 Hilux 4x4 & 05 Husky TE450
    Mar 2005
    Nowra, NSW
    this is what i plan on doing, if you are going 190kw 6-speed into a 175 4sp everything seems to be plug and play, got a few more things to check in my manual, but only one harness needs to be changed (easy one) and a reflash with tech to to link the bcm with ecu and pim, and change the instrument cluster software aswell,
    if you where going 4sp to 5sp, seems you will need to rip the dash out as the wiring is a wee bit different
    EASTERN CREEK JCNSW 2009
    Quote Originally Posted by Commydoor
    First of all your words cannot harm me cause my ego is like a shield of steel.
    vz bt1
    Dec 2008
    yeh im going the manual ... any idea on the price of a 190 motor and gearbox from a sv6 .. oh and how much do the 175 motors sell for and 4sp auto, so i know how much i can get for mine around.
    PaulSV6's Avatar
    PaulSV6 is offline CHE Tuned 156.8rwkw
    VZ SV6 M6, MY10 VE SV6 Sportswagon & MY03 XC SRI
    Jun 2008
    Castle Hill
    Hey mate,
    Its halfway down the list:
    COMMODORE VB-VE (ALL)
    $3750 Alloytech 190 Manual (brand new)
    The Blue One
    Quote Originally Posted by buddaboy1990 View Post
    bahahaha i thought u meant an actual turtle shell.... im such an idiot....
    Quote Originally Posted by STEALTHY™ View Post
    Quoted for truth
    05 VZ SV6 With VCM tune by CHE
    Mar 2009
    andyman's Avatar
    Mar 2005
    Nowra, NSW
    Quote Originally Posted by PaulSV6 View Post
    Hey mate,
    lolz thats one part of many that is needed, if you bought all the parts new it would have to be $6k+ in parts,
    im hoping to do this for $5 and thats with out selling all my other parts
  1. alloytec exhaust
    By Rob78 in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 27-03-2011, 01:47 AM
  2. alloytech v6
    By sv9946 in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 25-11-2007, 06:54 AM
  3. vz alloytech
    By VNV6VENGEANCE in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 13-06-2006, 02:25 PM
  4. Turbo For The Alloytech
    By VZSV6 in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 07-04-2005, 03:43 AM
  5. 190 kw Alloytech V6!!!
    By Wombat in forum General
    Last Post: 29-07-2004, 08:50 AM
