hi fellas
just wondering how the light cover thing comes off.
the main map light in the front cabin and the ones on the top each side of rear lights
and what size or type are they?
i want to change them to white ones,,, any recommendations on good bright white lights for those>?
Just use a small flathead screwdriver to gently pri-away the lenses. Dont use too much force otherwise you'll break them.
There called Festoon globes there are 11mm wide & about 41-44mm long. Use a tape measure to get the exact length then go to ur auto store. The aftermarket ones are LED globes, just ask when u go there.![]()
The Blue One
hey paul, how the heck do you take them out. Ive had a quick look and cant figure it out, or do they just pull out being festoon??
