Afternoon all...
Is there a right and wrong way to clean the engine bay..
I used to put degreasers on previous vehicles and hot wash but now
with eight coils and electrics sitting on the rocker covers..
Yes I intend expose the engine so I can clean the build up around oil filler neck and rocker covers etc...No real oil leaks just attention to detail
stuff!
I would rather ask advise of experts first..
Thanks in advance.
Levick.
just do your best to not get water on the coils/plug sockets/alarm and other electrics, maybe cover your coil pack with a rag or two also be carful with what degreaser you are using.. some heavy duty stuff can root your paint.. but spray on canned stuff from supercheap or whatever will be fine
My VT Berlina [LIONLW] - Lowered, 18's, Leather
http://forums.justcommodores.com.au/...tml#post863216
i just lightly spray the motor if the covers are off, if the covers are in the motor i just use the pressure cleaner on it, perfectly fine,
all the plugs and connectors on the these motors are sealed and water tight, so its no real drama with water on them
EASTERN CREEK JCNSW 2009
Originally Posted by Commydoor
A largish moderately stiff brush is also very helpful for cleaning dust out the engine bay (and the interior too actually, but I wouldn't use the same brush). You'd want to have the engine bay free of grease and oils first though (and dry).
DANJA'S CLEAROUT 2010 : Various VT-VZ parts, short shifters, performance parts. Check it out!
Originally Posted by Reaper
My choice of cleaner for the whole car is ChemTech CT18. For the engine bay i let it sit on there for 30mins and just hose it off
Glenn
Ill show you that im Australian if you show me your brazilian.
"I don't try to explain to people why I ride a Motorcycle. For those who understand no explanation is needed! For those who don't understand, no explanation is possible..."
Prob best to cover electrical parts with a small freezer bag then u spray degreaser over what needs cleaning.
The Blue One
most electrical connects are semi water proof now days. as long as you do not aim at the straight at them they are fine. degrease my VZ every month or so and no problemes.
