Results 1 to 5 of 5
Thread: ESP failure warning
    VZ Acclaim
    Mar 2008
    Taylors Lakes
    Default ESP failure warning
    Hi Guys,
    Just had my local mechanic replace my rack and pinion and service my '04 VZ Acclaim.
    Now I am getting an ESP Failure error messages, the mechanic plugged it into his aftermarket TECH2 thing and couldn't find any faults...
    Has anyone else had a similar problem or know what may cause it?
    Thanks
    Summer-Sickness's Avatar
    Summer-Sickness is offline 2005 VZ EXEC
    05 VZ Executive
    Jan 2007
    Rockingham, Perth
    bit of a stupid question, but checked the fuse in the engine bay?
    REHAB IS FOR QUITTERS!
    MY 2005 VZ EXECUTIVE
    VZ Calais MY06
    Nov 2006
    Canberra, ACT
    I always get problems with my ESP. It is the single most annoying thing about my car. I take it in to get it fixed and they say they had to adjust some sensor but the same thing will happen maybe a week later. I think it is something to do with it not reading the wheel speed correctly or something along those lines. I also found that when I had ESP failure, my car would have really rough gear changes. Hasn't happened for a while though so fingers crossed.
    You may need to take it into Holden the next time it happens. They should be able to track down the error stored in the logs. I have the feeling that I will be getting Holden to look at this problem every time I get it serviced.
    VZ Acclaim
    Mar 2008
    Taylors Lakes
    Thanks guys, took it to Holden today, it was the sensor in the steering column.
    I really hate ESP but I'm sure one day it will get me out of a sticky situation.
    Thanks again and i hope your ESP issues disappear one day hingo
    VZ Calais MY06
    Nov 2006
    Canberra, ACT
    Thanks mate. Glad you got it sorted.
  1. BCM failure
    By Calaber in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 10-05-2012, 06:22 PM
  2. VZ key failure
    By Juan in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 28-02-2012, 03:22 PM
  3. 'Rear light bulb failure' warning light
    By Misaprop in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 22-04-2006, 03:07 PM
  4. VX air con failure question
    By mjfs in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 14-12-2005, 01:14 AM
  5. Failure
    By Ms Stato in forum Jokes/Humour
    Last Post: 12-11-2005, 09:09 AM
