Hello everyone.
I have a new problem with my VZ Commodore.
When I go to start the car I get "Service Oil" error.
I've checked error codes nothing, so now I'm thinking when I last took it in
to service maybe they used the wrong type of oil? But I have done a lot of driving since then I don't understand why it wouldn't have come up before?
What could be causing the error and is the car still safe to drive?
Edit: Oil was new in the car after service before anyone asks, and i've checked oil levels they are fine.
and 3 Dangerous non ABS VN's
humm so can i still drive it ? and should i take this one to holden or to the same service centre as they promised to fix something they didn't do a good job on before.
If its a cluster error the car will drive no problem but for the chime. If it's the oil pressure switch - you may not know if the pressure fails. This would be unlikely in a young car - but not impossible.
I'd take it back to the place that serviced that car and get them to have a go if they have the scan tool.
Holden will be able to fix the cluster programming issue if it's that, and replace the oil pressure switch. (the switch was a little over $100 new)
thank you very much for that, but i have no chime nor do I have any light showing up on my dash, it goes away straight after I turn the car on.
if it was the oil pressure switch, service vehicle soon is usually the chime that sings
EASTERN CREEK JCNSW 2009
Originally Posted by Commydoor
I had the same msg in my car but its was "service eng Oil". Just took it to Holden they upgraded the software Cost $52. Told me it was a error on Holdens behalf for overseas models.
The Blue One
The Blue One
The Blue One
mine has been on for two days as well so i thought il try to get rid of it like the service message with ign off hold down up and down button while holding them down swith on ign release and press the set button and it is gone cheaper then going to holden for their mistake.
Service Engine Oil Soon, was a mistake by holden made on some of the local vehicles, just do a service reminder reset! mine did it at 20000km and was informed that warning was intended for export vehicles due to different servicing schedule. if your worried about it, check ya engine oil level prior to reset, only be worried if it appears again in a short period.
