Results 1 to 15 of 15
Thread: Need help vz exhuast droning!! And slower
    2004 VZ Berlina
    Apr 2009
    MELBOURNE!
    Default Need help vz exhuast droning!! And slower
    hey every1 i have a problem with my VZ Berlina seems to drone alot now. At the start it didn't as much but now is starting to kick in!
    is there anything i can do to stop or quieten the droning??
    and also since putting the exhaust on my VZ Berlina it seems slower??? throttle response wise!
    your help guys wood be appreciated
    thanxx
    itz a 2.5inch RedBack single Catback Exhaust
    No other mods done!
    vz sv6
    Apr 2009
    well it will be slower due to the loss of back pressure from putting the bigger exhaust on but it will be made up top, make it less droany is add an extra muffler into it (will also increase back pressure.
    one thing u can do i possibly do a few intake mods to get the car going a bit more therefore using the exhaust to its full extent
    PaulSV6's Avatar
    PaulSV6 is offline CHE Tuned 156.8rwkw
    VZ SV6 M6, MY10 VE SV6 Sportswagon & MY03 XC SRI
    Jun 2008
    Castle Hill
    Take it back to wherever u got the exhaust done & get them to fix it.
    2.5in is to big for the Alloytech 175, should be 2.25in!
    The Blue One
    Quote Originally Posted by buddaboy1990 View Post
    bahahaha i thought u meant an actual turtle shell.... im such an idiot....
    Quote Originally Posted by STEALTHY™ View Post
    Quoted for truth
    05 VZ SV6 With VCM tune by CHE
    Mar 2009
    Loss of backpressure does not lose power!! Its all about having the exhaust flow correct for the amount of exhaust gases produced by the motor. You want as little back pressure as possible!!
    2004 VZ Berlina
    Apr 2009
    MELBOURNE!
    Quote Originally Posted by torana355 View Post
    Do u know any ways that i can reduce the back pressure??
    Mar 2009
    Quote Originally Posted by BeKzZz View Post
    Exhausts can be complicated, the best way is to find a place that has dyno proven exhaust systems. I know Castle Hill exhaust in Sydney have actually tested their systems and tried all sorts of combos to find the best power/sound.
    To reduce Back pressure you want a straight through system though this will be loud.
    2004 VZ Berlina
    Apr 2009
    MELBOURNE!
    vz sv6
    Apr 2009
    actually i have been told from exhaust guys that have said is that the alloytec motors need backpressure as most NA cars do, as for the way the alloytec motor is designed as a fairly highly tuned motor from standard. but i would agree a single 2.5" might be slighty to big on a 175 where as it is one of the better systems to have on the 190.
    but i wouldnt swap ur exhaust i would just add more mods on the other end to push ur gasses out faster, likea pod kit or CAI system and maybe manifold insulators will all help with the power loss of ur vehicle which then making ur exhaust more suited to the power u will be making.
    VZ Calais
    Feb 2009
    I was told the 190 would be better suited to a 2.25" exhaust.
    Jesus is my Lord and Saviour
    VZ Calais
    sxcmonkey is offline SxcmonkeY
    VZ v6 commy
    Mar 2009
    NSW
    also "SUREFLOW" in ingleburn?
    they are well known for the "DRONE FREE SYSTEM" for commys
    as far as what i have seen, heard they are one of the best choice when it comes to exhaust for COMMY
    and i personally agree with the fact that back pressure is needed for NA engines as well as alloytech engines.
    I PERSONALLY THINK unless the engine has forced induction modifications exhaust wont need to flow as fast as NA
    it is like drinking a water with 1mm straw and 10mm straw... sort of idea..
    i dont know but they need back pressure.. lol
    if they didnt need back pressure manufacturers could make the exhaust FREE FLOW without any noise and all that drama but they dont, there is a reason for that.
    even if you upgrade your exhaust with aftermaket systems, there are only slight power increase, (that depends on what mods you have done, what sort of engine, and so on)
    well,, fix me up if i am wrogn.
    Mar 2009
    WRONG. You don't need back-pressure!!!! What you need for max power/torque is a straight thru system at the correct diameter for the engines exhaust output. It has to do with the way the exhaust pulses. Some people are very uneducated about exhausts....
    andyman's Avatar
    andyman is offline The Only 6sp VZ Wagon
    2012 BT50 4x4, 84 Hilux 4x4 & 05 Husky TE450
    Mar 2005
    Nowra, NSW
    oh my, plenty of threads about this, it has been proven for sound quality and performance increase wise a TWIN 2 1/4 is best suited to an alloytec,
    its proved single 2.5s make good high rpm power, and drone, as you have stated
    i have the twin exhaust off an 8, it has a nice little note, no power loss and and dosnt drone at 100-110km on the the freeway, my wagon with that exhaust and a 3.46 lsd gets 7.4 L/100km on a freeway run
    EASTERN CREEK JCNSW 2009
    Quote Originally Posted by Commydoor
    First of all your words cannot harm me cause my ego is like a shield of steel.
    ryno_vrx's Avatar
    ryno_vrx is offline Donating Member
    VR HSV enhanced Berlina
    Nov 2008
    Mirani
    pretty sure you need some back pressure.... atlest thats what every muffler shop i've been to has said n the reason i went from a 3inch down to a 2 1/2 inch exhaust on my vr 5lt and it made a big difference in power
    VZ Skaife Senator & VY SS UTE
    Jun 2004
    Quote Originally Posted by sxcmonkey View Post
    actually mate the reason car manufactures use tri flow mufflers and such is they are cheap and are very efficent at quietening the exhaust. high class car companies bmw etc do use straight through exhausts on their sports cars.
  15. #15
    VZ v6 commy
    Mar 2009
    NSW
    oh icic,,,,
    thanks for that fellas.
  1. exhaust droning
    By lockmac in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 15-09-2007, 01:03 PM
  2. need help my sc14 has made my car slower
    By Matt_vp in forum V6 Development And Modification
    Last Post: 05-11-2006, 02:16 AM
  3. VN V6 Exhuast
    By statesman_wagon89 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 30-03-2006, 03:10 PM
  4. Replies: 18
    Last Post: 18-02-2006, 10:16 PM
  5. Should school zones be slower?
    By Tasmaniak in forum The Pub
    Last Post: 15-09-2005, 05:20 PM
