I was browsing through forum threads, does the front bumper really need to be dismantled to fit some new bulbs in? That's ridiculous!
Anything else that can be done instead? I can access the driver side headlight bulb (small hands) but can't see a way to get access to the passenger side bulb.
I need to replace my low beam and parker bulbs on both sides. Surely it's gotta be easier than pulling half the car apart.
Firstly did u takeoff the plastic Radiator shroud (big plastic over) that will make it alot easier.
Once u take the Shroud off, you'll be able to take of the HL low bean cover.
The Blue One
Its easy for drivers side you need to move the battery..for the passenger side you need to take off the air intake tube and then its easy as..just twist and remove the back cover(grey) and then you can pull out the holder by taking the clamps off, parker you just need to pull the holder out ..replace the parkers then push it back again...
Ride: VZ SVZ
MODS: Darkest legal window tint
3 inch catback exhaust
Genuine Holden front strut brace
Xenon blue headlamps & number plate lights
CAI with POD setup
NEXT:
upgrade music system
thats ridiculous. it took me no sh!t 2 minutes. get a flat blade, undo the clips on the radiator shroud, pull it off. Unscrew the back of the head lights, and undo the metal clip behind each bulb. Then do the reverse to put them back in. Ive changed mine 3 times, its really not that hard.
same here.. we know all about that dont we troy lol
Seriouly, 6 screws to take the bumper off, 3 bolts to the headlight and then you've got 100% unrestricted access to the headlight. No swearing cus you cant fit your hands inbetween the intake and the light itself or that you cant see what way the bulb goes in.
Bloody car manufacturers! Why can't they make it easy to replace light bulbs, the pricks?
I guess people would steal them then...
hmmm. good point. how unaustralian of them lol
