Results 1 to 8 of 8
Thread: ve 16" interceptors on pre ve!
    91 VP BT1 5L
    Sep 2010
    western australia
    Question ve 16" interceptors on pre ve!
    been googling like a crackhead and cant seem to find any clear info. i know the centres need to be machined out to suit pre ve models. (if anyone has dimensions id greatly appreciate it!) others seem to think stud patterns different? personally i think this is a load of shit. but are VE studs smaller? bigger? will also require machining?
    another question is offsets etc... after being machined to suit. will they bolt straight onto say VN/VP live axle without dramas? sorry for all the questions just trying to find some straight answers. hope its in the right section too lol :P cheers in advance fellas.
    vr executive 5.0 M5
    Oct 2010
    wamberal
    hey chris18,
    i had the same probs re info, spoke to a wheel/tyre place they advised against using 16inch ve chasers on my vr as they said once the center is bored out to suit the strength of the rim is compromised because the lip around the hole will no longer be there. if anyone knows better please advise as i too would like to fit these to my vr cheers
    N/A
    Nov 2009
    Quote Originally Posted by chris18 View Post
    VE Stud pattern is the same, the studs are slightly larger in diameter, however since the wheels use a cone seat nut this is not an issue. The VE Centre bore is smaller so needs to be machined out to suit a pre-VE. Because the wheels are steel they are formed with a lip to make them hub-centric. By machining them out you are weakening the lip, hence it is not recommended to run these wheels on a pre-VE vehicle. Offset is the same between models (or close enough). Are they safe?? It's hard to say as any machining could potentially lead to cracking of the thinner inner lip which once it starts would only get worse and would likely crack all the way through to the stud holes (or worse). I'm not saying it can't be done, but from an engineering standpoint (and an engineer I'm not) I suspect it would be ill-advised.
    www.thewheeldeal.com.au
    Ask me for a great deal on tyres & wheels shipped Australia wide.
    vr executive 5.0 M5
    Oct 2010
    wamberal
    Quote Originally Posted by thewheeldeal com au View Post
    oh well that confirms it, better not take that risk thanks for the reply
    91 VP BT1 5L
    Sep 2010
    western australia
    yer. my brother in laws a machinist so i might have a chin-wagg with him about it. but it definately sounds like ill be better sticking to the 15's. just wanna roll stockies on the BT1, and 16's would be heaps better lol. ahwell thanks for the reply guys.
    EDIT: just had a word to my old man. and i think he has a point. instead of machining the wheel. cant i just get new discs and get the hubs machined to VE size? (i need new discs anyway lol) then your not comprimising any strenth. your simply making your hub the same size as a VE hub. thanks again.!
    N/A
    Nov 2009
    The discs slot over the hub and are hub centric too - you'd risk having the brake discs slopping around on the hub then....not something I would do. I suppose you could machine just the wheel side of the hub so you have a lip for the brake disc to seat on but geez you'd want to get it spot on....
    91 VP BT1 5L
    Sep 2010
    western australia
    brother in law gets paid a ridiculous wage so im assuming hes good at what he does! haha thanks for your reply's mate ill talk to him about it and way up weather its worth all the effort lol! thanks again.
    NVE_069's Avatar
    NVE_069 is offline Vx Calais / Ve Berlina
    Ve Berlina V6 - Wg Jeep Grand Cherokee V8
    Mar 2005
    I am running the Ve steelies on my Vx calais with 350+ rwhp no problems at all. been like that for a year now. Its 2 mill that needs to be done.
    But yeh not 1 single issue.
    Always In Construction Mode!!!!!
  1. Question about 15 x 7 steel wheels "interceptors"
    By bj42turbo in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 27-11-2011, 01:55 PM
  2. [NSW] FS/SWAP: Custom 16" VE Interceptors for Pre-VE cars. 16x8" & 16x7" & Tyres
    By VKCOMMO in forum Parts And Other Items For Sale
    Last Post: 22-05-2011, 06:01 PM
  3. [NSW] FS/SWAP: Custom 16" VE Interceptors for Pre-VE cars. 16x8" & 16x7" & Tyres
    By VKCOMMO in forum Swap / Wanted to Buy / Trade
    Last Post: 10-05-2011, 11:59 PM
  4. [QLD] (BRISBANE) Swap ROH RT 17" for 15" chasers/interceptors silver
    By Steven M in forum Swap / Wanted to Buy / Trade
    Last Post: 12-10-2009, 10:30 PM
  5. F.S: 15" Interceptors
    By GLDNVL in forum Parts And Other Items For Sale
    Last Post: 23-08-2007, 12:20 PM
