Results 1 to 8 of 8
Thread: 05 Vz S Ute (rear width)
    2005 VZ S Ute White
    Aug 2011
    Brisbane North
    Default 05 Vz S Ute (rear width)
    Hi i am looking at a set of Advanti A8 Afonso's in the Staggered Fittement!
    20x8.5 & 20x9.5 Rear! Will the 9.5 be too extreme even though its a Ute!
    The rear springs are only King Spring SuperLows!
    What would be best tyre size to fit them!! Also wanting to get guards rolled for extra piece of mind
    Thanks in advance
    Brad
    N/A
    Nov 2009
    Quote Originally Posted by Hershwon View Post
    Thanks in advance
    Brad
    Hi Brad,
    Yes 20x9.5 is too big for the rear of your VZ Ute.
    Another point to consider is that Advanti A8 Afonso is not available in Australia. I'd suggest having a look through the styles on our webpage to get a better idea of what is and isn't available to you.
    www.thewheeldeal.com.au
    Ask me for a great deal on tyres & wheels shipped Australia wide.
    2005 VZ S Ute White
    Aug 2011
    Brisbane North
    I now have 2 seperate prices to have these wheels delivered and you are the first person to tell me the 9.5 wont fit!! Will only require a guard roll as the +40 offset is perfect!!
    Thanks
    VKCOMMO's Avatar
    VKCOMMO is offline Carpark Mechanic.....
    Aug 2009
    Springwood, NSW
    How far do you want to go with it? You could tub the ute (easy because there arent any back seats) to the rails and then run basically whatever wheels you want, and whatever height you want
    [09-01, 22:47] HoZy: VKC doesnt finger, He fists... Because Ranga
    2005 VZ S Ute White
    Aug 2011
    Brisbane North
    I know wheels im getting!! I just need to know what tyres to get on them!!
    Im wanting 235/30R20 front and 245/30R20 possibly 255/30R20 as soon as i know whats needed i can get them!!
    VY Berlina V6 / R31 Skyline
    Dec 2008
    245/30R20 is the correct and legal size tyre (unless you have a 9.5" rim)
    Quote Originally Posted by xVisions View Post
    driving without a license at the moment, My vl has beaten every single car I've street raced!!
    N/A
    Nov 2009
    Perhaps I should have been more specific - It's do-able but we certainly wouldn't recommend it - you can fit whatever size wheel you want under the back of any vehicle with enough modifications.
    Regarding tyre sizes, I don't think you will find a 235/30R20 which is load rated for your VZ, but it's a moot point anyway because 245/30R20 is fine on the front anyway (on a 20x8/8.5 +45 wheel) and will be load rated. No need for a 235 front.
    As for the rear, you can't legally put a 245/30R20 on a 9.5" wide rim (not saying it won't fit) so you would put a 255/30R20. But this begs the question, why? All the added expense of having different front and rear tyres and wheels what is the benefit? ~10mm extra tread width, maybe a little more dish perhaps if that's what you are after. You are losing the ability to rotate tyres front to back whilst also exposing your rear wheel rims to pothole and gutter damage.
    Again, I'm not saying it can't be done just that we wouldn't recommend it. But at the end of the day it's your call.
    2005 VZ S Ute White
    Aug 2011
    Brisbane North
    Thanks. Thats wat i wanted some technical reasons y i cant not just u cant do it!
    Im not a wheels expert but im trying to learn as far too many mechanics take advantage if ur not clued in! Thanks for all helpful comments!
  1. VT series 2 rear track width - different to other late model Commodores??
    By jazza15 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 20-11-2010, 02:42 PM
  2. What is the max width rims you can have on a vh
    By redrags in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 12-03-2010, 09:53 PM
  3. VE Rim Width
    By JDW5560 in forum VE Holden Commodore (2006 - ?)
    Last Post: 09-02-2010, 02:05 AM
  4. About Width
    By wilca014 in forum VY Holden Commodore (2002 - 2004)
    Last Post: 04-07-2006, 07:03 PM
  5. Rear wheel bearing seals (width) drum V disk
    By digisol in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 11-12-2005, 11:42 PM
