Results 1 to 16 of 16
Like Tree1Likes
  • 1 Post By nasty1
Thread: Offset Issue
    Holden VZ Storm Ute
    Jun 2011
    NSW
    Default Offset Issue
    Hey guys,
    Just about to upgrade my wheel setup from some 17's to 20's but my wheel offset is going to change from +48 to +45 which means i'll have a -3mm offset? Is this alot and do i need to fix it? If so whats the best way to fix it?
    Any info will be appreciated!
    VY Berlina V6 / R31 Skyline
    Dec 2008
    3mm won't do much mate, should be fine. Will just sit 3mm closer to the outside guards. What's the width? I've run 19x8.5 +38 with no issues, 245/35 tyre.
    Quote Originally Posted by xVisions View Post
    driving without a license at the moment, My vl has beaten every single car I've street raced!!
    Holden VZ Storm Ute
    Jun 2011
    NSW
    Im running on 17x235x45 at the moment but moving up to 20x225x30 to keep it all legal.
    Dec 2008
    245/30R20 is the size you want.
    N/A
    Nov 2009
    As sweefu has pointed out, the change from +48 to +45 is a good thing and won't be a problem. Additionally you want to run a 245/30R20 if possible. 225/35R20 is OK but in some cases is outside the legal rolling diameter limit.
    www.thewheeldeal.com.au
    Ask me for a great deal on tyres & wheels shipped Australia wide.
    vy2 clubsport
    Feb 2008
    adelaide
    bumping up an old thread here.
    whats the lowest offset i can run on 19 or 20 inch to suit a vy hsv?
    Dec 2008
    Depends on what size tyre you want to run, what sort of suspension you are running, width of the wheel etc. Need more info
    vy2 clubsport
    Feb 2008
    adelaide
    20x8.5 or i may settle for 19x8s as for tyres well the rims will be a new purchase of ebay but i do have a set on 225/xx/20s in the shed.
    stock suspension in the vy but will lower the rear just a tad......
    as i have no idea on wheel offsets whats a minimum.
    Dec 2008
    The majority of wheels you'll look at will be +45 or +48, either of these will be fine. Only few wheels for Commodores will have an odd or lower offset.
    vy2 clubsport
    Feb 2008
    adelaide
    Thanks.the rims i looked at were offset to suit later model bmws so its a fair way off the highest i could find was a 38 offset.
    Oh well ill keep searching for wheels
    N/A
    Nov 2009
    Quote Originally Posted by nasty1 View Post
    What wheels are you looking at? Since this is our sponsor section, you've come to us with questions, why not let us know what you are looking for - you never know we might be able to help you out with what you're searching for.
    vy2 clubsport
    Feb 2008
    adelaide
    20 inch decorsa polaris 5's.dont think you will find them in australia anymore
    vy2 clubsport
    Feb 2008
    adelaide
    Found the rims ive been looking for but in 19inch with 42 ofset would i get away with this ALSO TYRES SIZE 235/35/19
    N/A
    Nov 2009
    +42 is fine but 235/35R19 likely won't have a high enough load rating for your car.
  15. #15
    VR commodore executive S2
    Apr 2011
    sydney
    Default looking for wheels n Tyler's
    I am looking for rims n rubber for my V R...
    Just want to know is the stud pattern the same right through the commodore range???
    N some suggestions would be good too...
    Pete.
    Attached Images Attached Images
  16. #16
    N/A
    Nov 2009
    Quote Originally Posted by v.r.holden View Post
    Pete.
    Yes Pete - aside from some very early 4cyl Commodores - they are all 5/120.
    Suggestions...without knowing what you like, what size you need, what your budget is...very hard mate. It's like saying "i need some shoes" and asking for a suggestion...Do you need thongs, Boots, Runners, High tops...how much do you wanna spend..?? what size do you need??....
  1. is 20+ to 38+ offset bad?
    By TonyJZX in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 03-01-2011, 03:20 PM
  2. VP/VR offset the same?
    By -UNKNOWN- in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 12-08-2009, 09:14 PM
  3. vu ss offset
    By picogrande in forum General
    Last Post: 03-05-2009, 06:14 PM
  4. VZ vs VE offset
    By andyman in forum General
    Last Post: 29-11-2007, 08:59 PM
  5. Offset
    By Stephen_Vn_Exec in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 08-02-2007, 06:36 PM
