Would VE GTS Replica rims with 245/35R20 tyres fit on my 2006 VZ SV8 sedan??
You need 245/30R20 tyres.
Are the 35's too big?? Do they rub?
unless your guards are heavily rolled they will scrub, rolling diameter is too big
So 245/30R20 will be fine even with full car??
i have 245/30r20 on my read and it scrubs with car load of people with stock susp and gaurds not rolled one thing i did find tho on the front u will need 225 wide to fit becuase the 245 hit the lower spring holder
IF YOU WANNA REV IT CHEV IT
Your wheels must not be the correct offset, with the correct offset 245/30R20 should not rub on the suspension at all.
Cheers guys
I know it's probably a bit different but on my vs a 245 won't fit with vt ss wheels up front, they too scrub the bottom spring holder, a 235 only just fits with a half a bees dick to spare
245's won't generally fit a VS front regardless of wheels.
ON VX - VZ models 245's can cause issues if running genuine factory wheels as they use a +48 offset. Most aftermarket wheels run a +45 offset and whilst it isn't a huge difference, it's enough to give clearance for 245's. You won't get the 245/35R20 to fit the VZ you need 245/30R20's > The Wheel Deal - Buy Achilles ATR Sport 245/30R20 93W
Will 225/35r20 fit my VZ?? Without scrubing or hit the strut??
thats what most people run mate, do u know what offset your rims are?
