+ Reply to Thread
Results 1 to 15 of 15
Thread: Rockers
    89 VN
    Feb 2009
    Default Rockers
    Hey guys will Yella Terra rocker from a VN S1 V6 fit straight into a VN S2 V6 with no mucking around just like when fitting them to a S1?
    Or will they be different?
    VN S1
    Jan 2008
    I think from what i have read the bolt sizes are different... but im only going by what ive read and been told.
    vn calais, vs clubsport #137
    Jun 2005
    Quote Originally Posted by needwork2-4fillhabbit View Post
    bingo,
    the rocker bolts are different sizes, no they wont fit easily.
    89 VN
    Feb 2009
    Nah thanks okay i will be best to get the ones that are made 4 it so there's no trouble.
    I have a question related to this. In a OHC engine the cams roll around and push down the valves, if you put bigger cams the hold the valves down longer giving a better performance.
    In a pushrod engine the cams at the bottom (or middle) roll around and push the rods which rock the rockers which pushes the valves down. If you put in better rockers they give it better lift make performance better.
    Is therefore changing cams or rockers on a buick 3800 only do the same thing as each other.
    This is my view on how it works i suspect I'm wrong so anyone is welcome to correct me as i would like to know how it works.
    Thanks again guys
    danja's Avatar
    danja is offline Swerves for gay koalas danja W427 danja W427 danja W427
    CBF 250 and a Levin ZR
    Mind Me Bloody Beer Champion!
    Jan 2006
    Quote Originally Posted by Leebo View Post
    Thanks again guys
    Cams and rockers do similar things, but not the same.
    A cam can change how far a valve opens (lift), and when it begins to open and close (duration - how long it's open). Rockers only let you alter lift, they can't change when the valve is actually open.
    Cams give you more tuning ability, but usually cost more by the time you factor in installation. This is why you often hear rockers referred to as "a poor man's cam".
    DANJA'S CLEAROUT 2010 : Various VT-VZ parts, short shifters, performance parts. Check it out!
    Quote Originally Posted by Reaper
    I think Joe Hockey is one of their best performers and I hope he gets [around] quickly - for everybody's benefit.
    2001 Manual VU ute
    Oct 2008
    Default 2 ECU failures in past 5 months
    Hi Guys, I have a 2001 VU ute manual bought it in january and have replaced the ECU twice in that time. I have replaced them with 2nd hand ecu's both times so I guess my question is has anyone else experienced this problem and have any suggestions for resolving it and also where can i get a good quality recon ECU as the new ones are $1200.
    Cheers Moose111
    89 VN
    Feb 2009
    thanks 4 the explination Danja. i may stick with rocker for the time being see if i like how the motor runs
    VZ COMMO STOCK
    Feb 2007
    MELBOURNE
    Quote Originally Posted by Moose111 View Post
    Cheers Moose111
    I have'nt heard too many issues with the delco computers, there may be a wiring issue thats causing the computer to fry, the best place to check this out would be a tuning shop as they may be able to check your computer to see whats happening,
    Micky.D
    YT
    89 VN
    Feb 2009
    VN S1
    Jan 2008
    89 VN
    Feb 2009
    VN S1
    Jan 2008
    VZ COMMO STOCK
    Feb 2007
    MELBOURNE
    Smile
    just found out it's a S1. lol
    Ah good stuff, that means no mucking around, just bolt them on
    Micky.D
    YT
    89 VN
    Feb 2009
  15. #15
    VZ COMMO STOCK
    Feb 2007
    MELBOURNE
    Cool Leebo
    can i get some prices on the yella terra rockers, pushrods and cams?
    PM sent
    Micky.D
    YT
+ Reply to Thread
  1. 1.8 Rockers for VN S1
    By Nevyn in forum Yella Terra
    Last Post: 30-08-2008, 07:33 AM
  2. rockers for my vs
    By joshooaahh in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 25-08-2008, 12:56 PM
  3. rockers
    By Jecs in forum Yella Terra
    Last Post: 21-03-2008, 08:55 PM
  4. VT 5.0 rockers/help pls
    By kato525 in forum Yella Terra
    Last Post: 05-04-2007, 01:22 AM
  5. VP Rockers
    By pow3rslave in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 20-01-2007, 04:16 PM
