Welcome to Just Commodores.
Just Commodores » Sponsors » Yella Terra » Roller Rockers hitting Valve Retainer
Yella Terra Performance and Supercharger Specialists - www.yellaterra.com.au
Reply
LinkBack Thread Tools vBmenu Seperating Image Display Modes
  #1
Old 07-06-2009, 10:43 AM
Ride: VR V6 Turbo
Trade Rating: (0)
300kwv6 Executive
Default Roller Rockers hitting Valve Retainer
Hi Guys,
I've had a ticking noise coming from the top end of my engine for a while. I originally thought it might be lifters, so these were replaced with a brand new set.
After I had the car on the dyno, the tuner said I may not have enough pre-load on the lifters. So I took a rocker cover off and had my mate take a closer inspection, he found some marks on the roller rockers and also skuff marks on the valve reatiner.
Roller rockers are YT 1:8.1, cam 225@50, 130lb double valve springs.
Here are some photos:
Is it safe to grind some material from the underside of the rocker??? I read somewhere you need approx 0.040" clearance.
What do you guys think??
Digg this Post!Add Post to del.icio.usBookmark Post in TechnoratiFurl this Post!Google Bookmark this Post!Yahoo Bookmark this Post!Bookmark to AskJeeves!Bookmark to Slashdot!Live Bookmark this Post!Spurl this Post!Reddit! Wong this Post!
Sponsored Links
  #2
Old 07-06-2009, 01:10 PM
delcowizzid's Avatar
Boosting Hard
Ride: T70 TURBO VN WAGON :D
Trade Rating: (2)
delcowizzid Caprice
i see no pics bumps for pics
__________________
Quote:
Originally Posted by savage1987 View Post
You're the reason I believe the youth of today are largely retarded.
  #3
Old 07-06-2009, 02:20 PM
immortality's Avatar
crappy ol' VN driver
Ride: VN3.8 5spd/VSII3.8/VH5.0
Trade Rating: (0)
immortality Senator Signatureimmortality Senator Signatureimmortality Senator Signature
can't see pics. may ahve to pack the rockers up and use longer pushrods. what is the installed height of the springs?
__________________
Body by Holden, Soul by Brock
the Legend will live forever
  #4
Old 07-06-2009, 03:08 PM
Ride: VR V6 Turbo
Trade Rating: (0)
300kwv6 Executive
Quote:
I fixed the link, so pics are now available
Quote:
How can lifting to rockers help? Not sure of the installed height? Is it simple as measuring it?
Thanks
  #5
Old 07-06-2009, 03:49 PM
vxcalais_01's Avatar
Ride: VX Calais 01 3.8lt Ecotec
Trade Rating: (0)
vxcalais_01 Executive
Wouldnt raising them alter the ratio ? Yella Terra should reply to this soon.
  #6
Old 07-06-2009, 04:06 PM
Ride: VR V6 Turbo
Trade Rating: (0)
300kwv6 Executive
Quote:
Changing the height won't alter the ratio, as this is set by the piviot point where the pushrod meets the cup in the rocker. If the point moves closer to the centre the ratio will increase and the opposite occures if its moved further out.
Your comments are appreciated.
  #7
Old 07-06-2009, 04:31 PM
Boosting Hard
Trade Rating: (2)
delcowizzid Caprice
i wouldnt be grinding them down it would weaken them a bit allso why do the springs hang out past the retainers
__________________
  #8
Old 07-06-2009, 04:50 PM
Ride: VR V6 Turbo
Trade Rating: (0)
300kwv6 Executive
I had the heads built by a bloke in QLD, so not sure why they stick out beyond the retainer. They are double valve springs so thay may explain it.
  #9
Old 07-06-2009, 05:12 PM
Boosting Hard
Trade Rating: (2)
delcowizzid Caprice
ide allmost say they retainers are the main issue being dished like that
__________________
  #10
Old 07-06-2009, 07:04 PM
chargedvx6's Avatar
Ride: VY SII HBD Calais L67
Trade Rating: (1)
chargedvx6 Berlina
Looks like the springs are shimmed on the base? The cheapest solution may be to install different spring retainers that sit below the valve head and remove or reduce the spring shims . This (in theory) should help retain the desired spring install height and improve rocker to retainer clearance.
If I'm wrong and there are no shims on the springs, a different set or retainers (about 0.120" lower install height) should still be able to be used even if it adds extra spring seat pressure. That is assuming the springs have enough travel in em
__________________
VYII Calais L67
  #11
Old 08-06-2009, 04:16 AM
Trade Rating: (0)
....or raise the rockers (shims, you can get special ones just for this purpose) and use longer pushrods. your only other option is to change the retainers but that will effect the installed height and seat pressures and possibly limit your lift (coil bind). unless you change the spring/retainers for a lower installed height items.
__________________
  #12
Old 08-06-2009, 06:07 AM
ScoHar's Avatar
Jizz in my pants
Ride: 02 VX Equipe V6
Trade Rating: (0)
ScoHar Calais
crazy subject to come up, huh immortality
__________________
Gas, Ass or Grass nobody rides for free
Quote:
Originally Posted by vsv8berlinawag View Post
You tell him (coz you are right)
  #13
Old 08-06-2009, 08:40 AM
TappetHead's Avatar
Ride: VT super6
Trade Rating: (0)
TappetHead Executive
Grinding clearance in the arms will weaken the rockers.
You need ro raise the rockers up with longer pushrods and taller pedestalls or shims under them.
You can see from the photo that the scallop is deep enoungh for the spring diameter but theres not enough valve protrusion from the retainer.
I would expect the geometry will be better when you do this but if not, you can use lash caps to get it back.
After you get the geometry right I suggest rubbing the damaged part of the rocker with fine emery paper to take the sharp edges off, or get the guys at YT to buff them out.
Call YT next week and see if there are taller pedestalls available.
Cheers.
Mark.
  #14
Old 09-06-2009, 08:00 PM
Ride: VR V6 Turbo
Trade Rating: (0)
300kwv6 Executive
Rang YT today to find out what my options are and it looks like the shims are the only way to go. YT don't make a longer pedistal or a thicker guide palte.
The standard pushrods are 7.950" the next size I can get is 8.000" which is 0.050" longer, so if I get shims 0.050" in thickness it might come close to solving the problem.
  #15
Old 10-06-2009, 06:29 AM
Trade Rating: (0)
get some different thickness washers and trial fit the rockers before deciding what you need.
__________________
  #16
Old 25-06-2009, 08:21 PM
VNracer34G's Avatar
Ride: VN Production Saloon
Trade Rating: (0)
VNracer34G Executive
Just confirmed out in the shed that S1 & S2 motors have flat topped retainers level with the keepers . S1 have a double spring stock, S2 a single with a smaller diameter retainer
  #17
Old 25-06-2009, 11:15 PM
Ride: VY S L67
Trade Rating: (4)
taztassio Executive
shouldnt have used double springs. you can get a single 130lb, which is apparently good for 700".
doubles seem to cause trouble on our heads
  #18
Old 25-06-2009, 11:16 PM
Ride: VY S L67
Trade Rating: (4)
taztassio Executive
u sure on that length? i thought standard push rods were 7.05" or 7.10", and the VT rods are 7.27".
ls1 are like 7.40"
  #19
Old 26-06-2009, 07:07 PM
Ride: VR V6 Turbo
Trade Rating: (0)
300kwv6 Executive
Quote:
ls1 are like 7.40"
Yes, Stock pushrods are definatley 7.950". The Ecotec are 7.05". The earlier Buick has a taller deck height so that the reason for the longer pushrod. Not sure of the LS1.
  #20
Old 26-06-2009, 07:10 PM
Ride: VR V6 Turbo
Trade Rating: (0)
300kwv6 Executive
I had the cylinder heads assembled in QLD, so the guy there did everything. I guess he could've used single springs, but I'm working with what I have.
Longer pushrods have arrived and have put shims under the pedistal, it looks like we are in business
  #21
Old 28-06-2009, 03:31 PM
Ride: VY S L67
Trade Rating: (4)
taztassio Executive
sorry, thought it was an ecotec
  #22
Old 26-07-2009, 05:06 PM
VNracer34G's Avatar
Trade Rating: (0)
Hey so how'd you get on mate?, this thread seems to have gone cold
  #23
Old 27-07-2009, 06:48 PM
Ride: N/A
Trade Rating: (0)
na3point8 has disabled reputation
i had ticking from my lifters 231 cam found next to no pre load fitted Trend 8" pushrods (crow are made by trend) now quiet as a mouse they were 161buks from performance wholesale. I have 1.6 roller rockers and 125LB comp cams double springs and retainers they dont have the big dish like yours do.
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Thread Thread Starter Forum Replies Last Post
roller rockers Macka21 VY Holden Commodore (2002 - 2004) 2 10-01-2009 10:22 PM
1.98:1 roller rockers 17UCK! VR - VS Holden Commodore (1993 - 1997) 0 11-09-2008 05:26 PM
ls1 roller rockers/ valve springs? Andrewss LSx Development and Modification 8 08-09-2008 05:10 PM
Where are my roller rockers? blakeb Yella Terra 4 03-09-2008 05:51 PM
roller rockers dunno vx V6 Development And Modification 4 03-08-2005 06:51 PM
Credit Consolidation | Credit Consolidation | Submit articles | Credit Consolidation | Internet Advertising | Car Reviews
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441 442 443 444 445 446 447 448 449 450 451 452 453 454 455 456 457 458 459 460 461 462 463 464 465 466 467 468 469 470 471 472 473 474 475 476 477 478 479 480 481 482 483 484 485 486 487 488 489 490 491 492 493 494 495 496 497 498 499 500 501 502 503 504 505 506
