hi i have just bought a YT stage 1 snout and 10psi pulley.
do i need to get some charger oil or can i just re-use the oil that is already in the charger if i am careful?
also is there anything else i need to change the snout over?
Hey ballin_sette,
You should change the oil when changing the snout as the oil is normaly really bad and smelly,
its only about $30 for the bottle to fill it.
you will need some ultra grey or sensor safe gasket goo too,
Micky.D
YT
