Page 2 of 2 FirstFirst 12
Results 26 to 42 of 42
Thread: 5L whipple kit
  1. #26
    vu ute m5
    Dec 2005
    townsville
    that looks so nice love it
  2. #27
    dirt drifter's Avatar
    dirt drifter is offline white trash hillbillie
    VS 5L M5 VS 6L M6
    Apr 2009
    massive hole in the ground
    very nice, suddenly im having second thoughts about getting a vortech. any idea what the intercooler setup will be worth?
    this is probably a stupid question but anyway how loud is it, can u idle around without making too much noise or does it sound like a cat stuck in a blender the whole time regardless of revs? personally i love blower whine its just a pity the coppers dont
  3. #28
    VZ COMMO STOCK
    Feb 2007
    MELBOURNE
    Quote Originally Posted by dirt drifter View Post
    The Cooler kit will be under 2k, the whipple's have a "sweet wine" when using mid to heavy throttle , lite throttle you could barely hear it
    Micky.D
    YT
  4. #29
    vn ss hdt aero
    Sep 2009
    looks very neat and subtle sitting there.
    How much power can be expected bolting on a stock 304, using its standard fuel pump, injectors and ECU?
  5. #30
    vs ss
    Oct 2009
    Quote Originally Posted by flanker View Post
    Your stock internals and ECU will be up to the task but don’t expect the standard fuel pump and injectors to keep up with this kit.
    The STD pump want be enough for anything over 200rwkw, this kit with the lowest drive ratio we could give it (7/8psi) and stock everything (engine/exhaust/throttlebody/ECU) will still pump out over 220rwkw.
    We have the option of auxiliary injectors to feed in the back of the Whipple but you will still need a pump, we’ve been using the intank Walbro 500.
    Cheers, Matt
    YellaTerra HI PERFORMANCE PRODUCTS
    AUSTRALIAN DISTRIBUTOR OF
  6. Default
    so basically you'd just be better off to upgrade the injectors and pump, then you wouldn't need the auxiliary ones? which injectors would you recommend?
    Quote Originally Posted by zai View Post
    I am not sutpid
  7. #32
    VP Executive R-spec
    Jan 2005
    The 42lb Bosch green tops will be more than enough even for the intercooled kit I'd say. They are good and easy to get etc
  8. #33
    Vt ss
    Oct 2009
    hi there just to let everybody know they are available and sorry but i had number 001 fitted on last friday. will look at posting some pics soon, regards spookster13
  9. #34
    vs ss
    Oct 2009
    Quote Originally Posted by levymetal View Post
    That's correct, the aux. inj. are a great option when running the Std injectors and Std chip with the TerraCharger kit.
    I would recommend go larger injectors (green) and pump with the Whipple Kit.
    Cheers, Matt.
  10. #35
    vs ss
    Oct 2009
    Hi Guys,
    The boys at HPF have just finished the first purchased Whipple production kit (YT4082-001)
    The customer optioned up to the polished unit and the YT 90mm T/B.
    The auto VT SS has completely stock internals and settled with 8/9psi producing 252rwkw.
    Here’s some pics on the dyno.
    Attached Images Attached Images
  11. #36
    eaton v8's Avatar
    eaton v8 is offline my little sleeper
    vz 6l auto 239cam 3.9diff
    Jun 2008
    gladstone qld
    do these whipples have the same bolt holes as the eaton 112 to the intake manifolds i like it i might upgrade that looks sweet
    Experience is a hard teacher. First you get the test, then you get the lesson.
  12. #37
    Vt ss
    Oct 2009
    Hi there eaton v8, not knowing what your eaton is like but this is my first blower i am loving it, waited so long for it. But good things come to those who wait. Talk to Matt at yella terra, hell of a good guy to talk too. regards spookster13.
  13. #38
    muvro's Avatar
    muvro is offline TUFF 6
    VT Calais S1 L67 A4
    Jan 2006
    Looks Awesome!
    You can't beat whipple blowers!!!
    I love being blown!
    VT Calais with a Whipple blown 4.2L stroker.
    Mods;
    -Pro race 4.2L Pro-stroke stroker kit, prepared and assembled by Pro-Stroke.
    -Custom grind Ivan Tighe cam.
    -YT Ultra lite rockers
    -YT customised whipple adapter.
    -3.3L whipple blower.
    -TRK Icebox and by-pass setup.
    -TRK 2" extractors, 4" collectors and cats, into dual 3" X-Force exhaust.
    -Heads are currently standard.
    -EMS 8860 ECU tuned by CV Performance
    400rwhp and climbing....
  14. #39
    VT_II_Calais's Avatar
    VT_II_Calais is offline Car Whore
    VT S-Pack Supercharged V6
    Jan 2007
    vn ss hdt aero
    Sep 2009
    Quote Originally Posted by YTerra TECH View Post
    Hi Guys,
    hes got to be happy with that!!!
    Im saving for one of these babies
  16. #41
    VT super6
    May 2006
    Wink
    Quote Originally Posted by VT_II_Calais View Post
    Just wondering if you've got any 0-100kph and/or 1/4 mile times?
    Not as yet, but we have more kits going out this week so i would think that we will get some feed back very soon.
    Micky.D
    YT
  17. #42
    Jan 2007
    Quote Originally Posted by TappetHead View Post
    Micky.D
    YT
    Nice, looking forward to the results!
  1. Whipple upgrade for L67
    By BIG-EV in forum Yella Terra
    Last Post: 11-09-2009, 12:16 PM
  2. Whipple progress
    By joshsvs in forum Yella Terra
    Last Post: 28-03-2009, 01:36 PM
  3. Whipple superchargers
    By Shanus69 in forum Yella Terra
    Last Post: 23-03-2009, 01:19 PM
  4. Holden V8 Whipple setup.
    By metalhead in forum Yella Terra
    Last Post: 12-03-2009, 10:32 AM
  5. Intercooler for a holden 5L with a 2.3L whipple.
    By 97 SEN in forum Yella Terra
    Last Post: 14-02-2008, 12:19 PM
