Results 1 to 8 of 8
Thread: Release of the New Range of V2 Intercoolers
    VZ COMMO STOCK
    Feb 2007
    MELBOURNE
    Post Release of the New Range of V2 Intercoolers
    The V-2 was a world-shifting technological quantum leap that changed the face of weaponry. Extensive aerodynamic and advanced cooling technology was used at the time. Now the new Yella Terra V6 intercoolers (named V-2) are also leaps in water to air inter-cooling and now have been released for your weapon of Choice
    Brand New Just Released !!!
    Yella Terra Hi Performance Stage 2 Under blower Intercooler Unit
    To SUIT HOLDEN SUPERCHARGED 6 L67 VS- VY
    This Yella Terra unit will allow you to increase your level of boost and performance.
    No other product comes close
    The product is the ultimate design for the forced induction Holdens allowing you to get more boost into your Supercharged L67 engine ..... and the fact is intercooling is the key to making power.
    The product features:
    Superior Water Flow Rates
    Single Pass flow configuration which is superior as compared to the inferior to counter-flow configuration of other units
    Full floating isolated Multi Finned Heat exchanger Core
    Highly Efficient - Fills the complete intercooler core with 100% cold flow upon entry as opposed to filling 50% of the core with cold flow and 50% pre heated return flow
    Single pass design enables slim-line deck-No Modifications required to fit
    Built in PCV system-no need to drill access holes
    Utilizes purpose built Heat Exchanger design with better surface area for more efficient heat transfer -unlike other inferior general purpose automotive heater core designs
    Aluminium Billet cnc machined body - no soaking of engine oil as compared to composite materials
    Precision CNC machined plates - Better sealing to Supercharger and Intake Manifold
    No buckling or warping
    No fear of cracking due to brittle material upon installation
    CNC turned Billet Aluminum 3/4 fittings for plumbing
    All serviceable parts
    Larger Incoming and outgoing primary water reservoirs
    Suitable for use with water,glycol or water /glycol mixtures
    All "O" ring assembled - no sealastic used and easy servicable
    Suits Generation 5 blowers
    New Slim line design - no modifications to fit
    No Bonnet Mods required!!!!!!
    The most efficient under bonnet bolt on Water to Air system available in Australia and the USA
    100% pressure tested and QA approved.
    Manufactures Warranty
    Very Aesthetic and factory look
    Micky.D
    YT
    Attached Images Attached Images
    BJ31OS's Avatar
    BJ31OS is offline Supercharged VT
    Supercharged Series 2 VT
    Sep 2009
    Newcastle
    VZ COMMO STOCK
    Feb 2007
    MELBOURNE
    vu ute m5
    Dec 2005
    townsville
    VY SII HBD Calais L67
    Dec 2006
    Says it suits GEN 5 blowers Mick, I assume it also suits GEN 3 M90s as well? How thick is the actual core and not the mounting plate?
    VYII Calais L67
    vu ute m5
    Dec 2005
    townsville
    VZ COMMO STOCK
    Feb 2007
    MELBOURNE
    Wink Yt
    Quote Originally Posted by chargedvx6 View Post
    Yep All GEN 3,4,5 ;o).
    The full assembley is 50mm heigh, which houses the unique single pass core.
    Mike
    YT
    VZ COMMO STOCK
    Feb 2007
    MELBOURNE
    Wink Yt
    Quote Originally Posted by aussiguy87 View Post
    does this cooler suit the whipple v6 kit?
    Na the Whipple kit uses a different bolt pattern, very simular core design though ;o)
    Mike
    YT
  1. intercoolers
    By vy low in forum VY Holden Commodore (2002 - 2004)
    Last Post: 08-03-2007, 05:48 PM
  2. Water to Air Intercoolers
    By defa in forum General Discussion
    Last Post: 15-01-2007, 08:29 AM
  3. GROUP BUY - New front mount intercoolers $145
    By GTS1963 in forum Swap / Wanted to Buy / Trade
    Last Post: 24-04-2006, 10:01 PM
  4. Intercoolers
    By smileyau in forum Parts And Other Items For Sale
    Last Post: 20-08-2005, 07:56 PM
