Page 1 of 4 1234 LastLast
Results 1 to 25 of 99
Thread: New 5.0L Yella Terra Whipple Kits !!!!!!!!!!!
    vs ss
    Oct 2009
    Post New 5.0L Yella Terra Whipple Kits !!!!!!!!!!!
    New Yella Terra -Whipple Supercharger Tuners Kit for Holden 5.0 litre is available NOW!!!
    For all you guys who have been waiting for so long for this kit …it is now finally out and Yella Terra is taking orders.
    The latest and greatest power upgrade for the Holden EFI V8. Based on the 2.4 litre twin screw supercharger, this new kit offers high boost potential on modified engines and custom tuning.
    The results non intercooled are 250Kw + rear wheel power potential from an injected 5.0 litre with mind blowing torque and excellent drivability.
    This kit suits all VN-VT EFI 5.0 litre engines from the STD 304 right through to the 383 stockers.
    The new Holden Twin screw tuners kit comes complete with :
    New generation 2.4 litre twin screw compressor with a 750HP potential.
    CNC Machined open planum manifold with o-ring sealed billet top plate.
    Cast rear intake to take STD or the Yellaterra 90mm throttle bodies.
    Auxiliary ports designed into the intake for extra fuel injectors, methanol or NOS
    Built in billet bypass system
    CNC billet snout and independent front blower drive system in 6 or 8Rib
    Integrates with the factory fuel rails and lines
    Remote 2BAR MAP sensor and plug and play extension loom for T/B
    All hoses, bolts, clamps and hardware supplied.
    Complete step by step fitting instructions.
    This entry level kit is non intercooled kit and set up to run 8-10psi with a strong 250+ rwkw power potential.
    Its designed to be simply upgraded to the intercooler option for the 300+ rwkw applications.
    Retail Price: $7545 (gst including)
    OPTIONS:
    Water to Air Intercooler System (available Dec 2009)
    YT 90 mm Performance Throttle Body
    8 RIB Pulley and belt upgrade
    Customer/Tuner will need to provide depending on setup:
    Larger than Std injectors, upgraded fuel pump and retuned ECU.
    Cheers, Matt.
    YouTube - Yella Terra's 2.4 Whipple Supercharger on Holden 308 (pt 1)
    Attached Images Attached Images
    YellaTerra HI PERFORMANCE PRODUCTS
    AUSTRALIAN DISTRIBUTOR OF
    HoZy's Avatar
    HoZy is offline //There Ain't No Rest For The Wicked...
    BMW E39 540i
    Jul 2004
    S/E Subs, Melb
    Beautiful looking kit, Will have to see how funds are next year... ^_^
    MaT
    Quote Originally Posted by garth
    well if it isnt mr i only have temp bans. how long you intending on staying this time hozy.
    dirt drifter's Avatar
    dirt drifter is offline white trash hillbillie
    VS 5L M5 VS 6L M6
    Apr 2009
    massive hole in the ground
    hey mate if i get one of those with the intercooler setup will everything still fit under the bonnet of a vs?
    if it does, is there any chance of keeping my strut brace on with this setup, with or without the intercooler? i've got a whiteline brace at the moment that runs straight across between the strut towers however nolathane's brace has a bend in it and sits back near the firewall, im hoping if one wont fit the other will
    if my rig was a street/drag car i wouldnt care but it will be a wkend track day toy one day so i would try and have a brace on there if possible
    im sure u blokes will have a trade stand at summernats, any chance of bringing along a commie with this kit bolted on? it would be great to have a close look at one
    VX Calais 01 3.8lt Ecotec
    Jul 2006
    Almost worth selling the VX, buying a 5.0L and using the change to get the system !!! HOw is this system on the original bottom end ?
    Vt ss
    Oct 2009
    Quote Originally Posted by vxcalais_01 View Post
    Hi there vx calais in those pictures mine is the red motor kit # 001 i can tell you that mine is a completely standard engine, if i was to go intercooled i would have to consider engine mods, but YT guys would be able to give you a better idea. since photo's were taken i have had the welds on the stainless air box to throttle body re welded and brushed back to a satin finnish so now it looks like it's one piece.
    Jul 2006
    Quote Originally Posted by spookster13 View Post
    Well done mate, looks fantastic !
    betts's Avatar
    betts is offline Double banger
    Built toyota surpa
    Nov 2005
    Just around the corner
    Wow, the black one is pure sex. Any comparisons in torque figures between the whipple and the eaton m90?
    vs ss
    Oct 2009
    Quote Originally Posted by dirt drifter View Post
    The manifold is designed to be intercooler ready which houses the W2A core inside the manifold which won't effect the hight.
    The kit will look no different than the non intercooled kit from the out side except for two water hoses coming out of the front of the manifold.
    The whole kit doesn’t sit any higher than the STD manifold. Plenty of our Whipple kits have been sold with the customers running strut bracers.
    We are always on display at the Summernats and the R&D car known as “project plum” will be on display and cruising the grounds, as well as a kit on display, assembled on a stand.
    Cheers, Matt.
    Dan355's Avatar
    Dan355 is offline Go THE SS's
    Street Legal 355ci VN SS - Daily: VP SS
    May 2006
    Have you guys run any of these on any 355ci motors yet? Just want to know how they go on a larger motor. I think i saw one of these at the extreme horsepower show here in adelaide a couple of weeks ago. Looks as though the one in the pic sits higher, different kit?
    vs ss
    Oct 2009
    Quote Originally Posted by Dan355 View Post
    There is a couple of customer 355/383 builds on the go now who have purchased our 2.4L Whipple kit.
    The 2.4L Whipple unit used in our kit is designed to support over 700HP and will work effortlessly on a 383 stroker.
    We have supplied a lot of custom kits over he years before the production kit was available.
    The custom kit in the pic we used the larger 3.4L Whipple which is quite a bit taller and longer and won’t fit under the bonnet, the rest of the kit’s hard ware is the same.
    This will be available as a off the self kit early next year but will be around $2000 more than the current 2.4 Whipple kit.
    Cheers, Matt.
    Boonz's Avatar
    Boonz is offline the holden mechanic
    green 355 VG ute , silver vx s pac L67
    Jul 2005
    berri, south australia
    shanhsv's Avatar
    shanhsv is offline Luvo
    VS Berlina V8 5speed
    May 2005
    Muswellbrook,NSW
    Quote Originally Posted by YTerra TECH View Post
    Cheers, Matt.
    Do you mean the 3.4L will be off the shelf at 2k more or is the 2.4 going up
    WTB:VR/S HSV 250km/h speedo cluster
    Dan355's Avatar
    May 2006
    Cheers, Matt.
    Nice! So where do you see the limitations with the 2.4L whipple on a 355? Is the 2.4L only capable of up to 10psi?
    vs ss
    Oct 2009
    Quote Originally Posted by shanhsv View Post
    No, the 2.4 kit will remain at the advertised price of $7545inc.
    If we see a market and decide to release the Monster version of this kit it'll probably be around $2000 more.
    The current 2.4 Kit is more than enough blower to handle the extreme builds.
    Cheers Matt.
  15. #15
    vs ss
    Oct 2009
    The 2.4L screw based blower is capable of 20+ psi and producing efficient power up to 18,000rpm blower speed.
    It's the perfect match for the 355/383 strokers.
  16. #16
    Dan355's Avatar
    May 2006
    Excellent! So why do people opt for the 3.4L kit? I assume cruise control and kick down for the autos are retained? Looks one cable short in the pics. Do you guys offer finance? lol
  17. #17
    VE SS and VS Senator 215i
    Jun 2008
    Adel
    Matt, could you please post results of the new kit as you here about them? Cheers
  18. #18
    VS 5L M5 VS 6L M6
    Apr 2009
    +1. i'd love to know what these kits can do with a strong 355 bottom end and more boost
  19. #19
    XR8
    May 2008
    VXSS II
    Jun 2008
  21. #21
    betts's Avatar
    Built toyota surpa
    Nov 2005
    Quote Originally Posted by ChargedBT1 View Post
    no after market charger or turbo kit is adr compliant
    Not entirely true, MWS in WA does an eaton M112 supercharger kit that is adr compliant. It is one of only few that are though.
  22. #22
    vs ss
    Oct 2009
    Quote Originally Posted by gts_215i View Post
    are these kits adr compliant & emmissions legal ?
    Both our 1.5L TerraCharger and 2.4L Whipple kits are engineered and manufactured to be ADR Compliant.
    With low boost and good condition cats they will pass emissions testing.
    Alot of our 5.0L kits are out there with ADR approval.
    Just keep a small high boost pulley in the glove box for when you leave the testing station.
  23. #23
    Troy5L's Avatar
    Troy5L is offline building a lemon
    Blown VS Clubsport, Hektic Bravo ute
    Jun 2005
    Mornington peninsula
    im kinda sure that the vortech's can also be adr approved, ive heard a few people have also passed emission tests with them..
    nice kit!!!the torque would be insane
    Vortech V1 supercharger : 10psi : Intercooled : 3.89 Mini-spool : VT Big Brake conversion : Shift kitted auto : B&M Shifter
    My VS CLUBBY!
    237.2RWKW - 318.1HP - 926.4 NM
    Quote Originally Posted by ari666 View Post
    "putting additives in your oil is like putting things up your bum.... to some people its the best thing in the world, but to me its the most horrid thing i coud possibly imagine"
  24. #24
    VP Executive R-spec
    Jan 2005
    Do they come with a note to say this? is that what you need when the epa comes knocking? anyway this is most helpfull information to know
  25. #25
    vu ute m5
    Dec 2005
    townsville
    are there any dyno sheets of one yet? power vs torque
  1. Yella Terra
    By MICKY.D in forum V6 Development And Modification
    Last Post: 23-06-2009, 03:45 PM
  2. Yella Terra
    By MICKY.D in forum LSx Development and Modification
    Last Post: 23-06-2009, 03:26 PM
  3. Yella Terra Terra Charger
    By INDACLUB in forum Yella Terra
    Last Post: 22-09-2008, 09:12 AM
  4. yella terra
    By korny in forum LSx Development and Modification
    Last Post: 22-01-2008, 05:54 PM
  5. Yella Terra 1.7 RR for VR?
    By Simdog in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 15-08-2006, 12:00 AM
