Results 1 to 9 of 9
Thread: Do you RR bolts strech?
    TI3VOM's Avatar
    TI3VOM is offline VT V6 wanting 300RWHP
    VT V6 Acclaime S1
    Feb 2009
    Somewhere
    Default Do YT RR bolts strech?
    Hi there mate I was wanting to know what kind of bolts you use with you're rocker packages?
    The store I got mine from ordered some mixed ratio ones for me. When I picked them up they said to make sure to put the higher ratio ones on the exhaust valve.
    Long story short I have a VT V6 N/A so I want to put the higher ratio on the intake valve.
    Do the bolts you supply with you're RR's stretch? Would I need to use new bolts. If so how much would it cost to get some?
    Glenn.
    acarmody is offline Donati..Whoa Green
    VX Berlina
    Apr 2007
    Are you sure you can put the higher ratio ones on the intake? Wouldn't it have been better to get all one ratio?
    I thought the reason you got higher ratio for the exhaust is because the air is being forced down into the engine under pressure by the supercharger, but it doesn't have that benefit on the exhaust cycle so it increase the lift of the exhaust valve to allow it more space to escape.
    Ronald Reagan (1986)
    TI3VOM's Avatar
    VT V6 Acclaime S1
    Feb 2009
    Somewhere
    Cheers for that acarmody.
    I understand what the higher ratio on the exhaust with a supercharged engine does, it helps bleed off the boost inside the cylinder, to help fit more mix in next time round.
    When I bought them I said I wanted some 1.9 ratio roller rockers, when they arrived they had ordered a mixed ratio set. I was not fussed as either way there would be gains and being mixed ratio's there would be the tiniest bit more gain.
    But as I was leaving the guy said to make sure the 1.95's go on the exhaust side, he did not ask whether it was supercharged or not, so I did just that.
    But being N/A it would have been better to put the 1.95's on the intake side, as the exhaust has the force of the explosion behind it to push it out, where as the intake just has the amount of lift (I think).
    I just need to know if the bolts stretch?
    immortality's Avatar
    VN3.8 5spd/VSII3.8/VH5.0
    Apr 2006
    Auckland NZ
    what type of bolts are they? if they are cap screws then they are re-usable. if they are the factory style bolts then get some caps screws. the re-useable bolts that Intense racing from US supply are just cap screws
    all bolts stretch. it's the amount that you stretch em that dictates whether or not they are re-usable
    Body by Holden, Soul by Brock
    the Legend will live forever
    TI3VOM's Avatar
    VT V6 Acclaime S1
    Feb 2009
    Somewhere
    Can't say I know what type they are, that's why I was asking the bloke from YT. Is there a way to tell the difference?
    VX Berlina
    Apr 2007
    I don't know if this will help, the left two are factory bolts, and the right one is my reusable bolt, available from any bolt store for about 50 cents each, better than about $5 each for Holden one time use bolts.
    TI3VOM's Avatar
    VT V6 Acclaime S1
    Feb 2009
    Somewhere
    Ill have to have a look, as I installed the rockers 1 year ago, but I'm sure they came with the reusable bolts.
    Cheers for the help guys.
    VZ COMMO STOCK
    Feb 2007
    MELBOURNE
    The bolts used in our rocker sets are unbrako socket head cap screws.
    The 5/16 bolts used on V6/V8 engines are rated to handle 400. ft lbs, i have re-use the same bolts many times, i only get new ones if they look like they are damaged or stripped, shouldnt be an issue at all to re-use them
    Mike
    VX Calais 01 3.8lt Ecotec
    Jul 2006
    Quote Originally Posted by G.C.Photography View Post
    Same principal as mild cam and head work on Naturally Aspirated..... air out of the heads through the exhaust valves is the key to making some power. Correct me if i am wrong.
  1. ARP bolts
    By DANNY8 in forum V8 Development and Modification
    Last Post: 11-03-2009, 02:37 PM
  2. Flyweel Bolts S1 (6 bolts) How Do i Remove? Reverse or Normal?
    By social in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 02-01-2009, 10:54 AM
  3. cat bolts
    By ear099 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 21-02-2007, 03:14 PM
  4. vn/vp wheelchair strech taxi
    By mrc in forum Swap / Wanted to Buy / Trade
    Last Post: 21-01-2007, 07:41 PM
  5. vn/vp strech wheelchair taxi
    By mrc in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 21-01-2007, 03:18 AM
