Results 1 to 4 of 4
Thread: yella terra microtech mf-1
    vs ute blown 5.0
    May 2010
    Default yella terra microtech mf-1
    gday there
    would you be able to help me out?I purchased a belt driven 8psi supercharger for my vs 5ltr Ute.very happy with product
    when I purchased the product it came complete with a microtech mf-1 and two separate injectors.
    could you please tell me the standard settings for the three dials on the mf-1
    im not sure what the first dial is, it has CHANNEL ONE above it, so i have it on 1 (the microtech is only running the two injectors only)
    the second is aux fuel start and i have that set at 4, does that mean it opens injectors at 4psi and if so is it a constant flow or does the flow increase with more boost applied.just a bit worroed about it leaning out from 1-4 psi if that is the case, and the third is enrichment and its set at 50%.
    the only mods are that i have upgraded my injectors to 30 psi and the memcal is at the moment being set to run thos on standard config.other than that there are no other mods to be worried about.
    any info will help. info needs to be punched into me a few times so can you keep it simple mate
    cheers
    Attached Images Attached Images
    VZ COMMO STOCK
    Feb 2007
    MELBOURNE
    vs ute blown 5.0
    May 2010
    Nov 2004
    hey Mick,
    you got a wireing diagram for the Mf-1 around at all?
    Dan
  1. Yella Terra
    By MICKY.D in forum V8 Development and Modification
    Last Post: 25-07-2009, 09:01 AM
  2. Yella Terra
    By MICKY.D in forum V6 Development And Modification
    Last Post: 23-06-2009, 03:45 PM
  3. Yella Terra Cai
    By Charg'd in forum Yella Terra
    Last Post: 23-03-2009, 01:50 PM
  4. Yella Terra Terra Charger
    By INDACLUB in forum Yella Terra
    Last Post: 22-09-2008, 09:12 AM
  5. yella terra
    By korny in forum LSx Development and Modification
    Last Post: 22-01-2008, 05:54 PM
Tags for this Thread
