Hey MickyD.
Time to annoy you again lol.
3 questions in random order.
Im due for rego so is the Terracharger ADR37 compliant in NSW and will i need an engineers?
Would a 90mm throttle body be of any benefit with say 36lb injectors and if so do you make one for the 5lt with TPS and IAC switch positions?
Do you have any tuning directions for the MF-1?
William.
wjpankhurst@msn.com
Hey William,
hahahaha ,no stress mate.
ok so number 1 = no , unfortunetely not. yes you need to pass epa and engineering test if they want to be anal.
a larger t/b would give it a little more poke over the standard unit , we are working on a new 90mm t/b for the 5.0L now , hope to see something in the next month.
yes i have the instructions for the MF-1, will send them now .
Mike
YT
sorry MickyD dunno if there was a prob but they didnt come through can you please resend...
William.
Micky any updates on the 90mm throttle body? Will it have the position for the ICS as well as the TPS or will it be like the eBay ones with TPS only?
Any guestimate on a price. I have some 36lb injectors, an 044 pump, surge tank and new fuel reg to fit as a bit of a test with the terracharger and
am thinking a 90mm throttle would be a good test at the same time. Just tinkering around with no goal in mind just want to play with it.
ps can you please resend the MF-1 instructions again i seem to have lost them. wjpankhurst@msn.com
