Hey,
I'm chasing the instructions for the Terra Charger on the 304's, as i pulled mine off for an engine rebuild and now i can't figure out where any of the vacuum hoses etc go...You can send them to nlparadise@hotmail.com if you want. Also, how much are the 90mm TB's to suit? Tried calling you guys but couldn't get through.
Cheers in advance, Nick.
done,
Mike
YT
Hi,
I'm also chasing the instructions for the Terra Charger YT4081 on the 304 VR SS im installing. I can't figure out where any of the vacuum hoses go either. Is there a basic setup for micro fuel..?. If you could.. can send them to xlr8ford@hotmail.com please.
Thanks
Clinton
Hi,
Just bought vs with 4081 blower, 30lb injectors 90mm TB, yt intercooler (do these make a difference the hoses look kinda tiny!)?
Also has some sort of cam and yt rockers. Was doing 240rwkw bit is now running terribly. misfiring i think, clacking/knocking or something like that at revs over 3k, under heavy throttle
it will simply die and live again every few seconds suspec bad AFR?? Could be something amiss inside engine but noises sound more like exhaust leak than anything.
And the plugs were nice n black when i cleaned them today (cyl6 was far less black that rest, rather brown and crusty sorta!) and note no improvement from cleanimg plugs.
Is the microtech necessary woth 30lb injectors? Also is vac connection from factory fuel reg on end of rail supposed to be connected to vac or something? Mine is not..
Have 58mm pulley on, have 61mm pulley can put in if need be while fault-finding..
Any ideas? Or diagrams how things are meant to be? Info on microtech mf1?
Thanks in advance,
Dave
*59mm.. typing on phone (worst!)
