Results 1 to 7 of 7
Thread: can i fit a top mount supercharger on my stock v6 ecoctec?
    2003 VY II S-PACK
    Feb 2011
    Perth, Rockingham
    Default can i fit a top mount supercharger on my stock v6 ecoctec?
    just wondering if i can get a top mount supercharger like the factory one for my stock ecotec? and do they come in a kit and do they just bolt on or do i need to change heads etc?
    2DIE's Avatar
    2DIE is offline ONEDOLLAHOLLA
    97 Acclaim
    Feb 2008
    South Aus
    You need the heads and leads and injectors and computer and pulleys, probably some other stuff I have forgot as well.
    Sometimes on ebay you will see a conversion kit for around $1000-1500 or even better the whole motor, loom and ecu for $1500-2500
    Best RPG ever
    2003 VY II S-PACK
    Feb 2011
    Perth, Rockingham
    VS ute
    Nov 2008
    get a l67 of ebay or the likes for about 2500ish bit cheaper if you watch it. will handle alot better and put out more abuse then a ecotec
    FstStig's Avatar
    FstStig is offline Diagnostician
    1993 VR Calais
    Sep 2008
    Newcastle/Central Coast, NSW
    Better off getting a whole L67 motor with computer and wiring harness. The L67's have a stronger bottom end. Easier to just do a swap over, probably cheaper in the long and short run as well.
    If it's not a Symptom its not relevant, and if its not relevant I don't care!
    VX Calais 01 3.8lt Ecotec
    Jul 2006
    Yella Terra - Browse all product categories
    Yella Terra have a Supercharger made to bolt onto the v6 ecotec. You need to change the head gaskets to lower the compression, otherwise thats it.
    http://www.yellaterra.com.au/product...goryIdentity=5
    Direct bolt on top of an ecotec. Do i search, theres another member even running it with mixer lpg which is what i intend to do.
    VZ COMMO STOCK
    Feb 2007
    MELBOURNE
    Quote Originally Posted by vxcalais_01 View Post
    Yella Terra - Part details
    Cheers vxcalais_01
    Mike
    YT
  1. What do i need to change to on my stock VR v6 to install a stock supercharger kit?
    By holden_w427 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 28-07-2010, 01:48 PM
  2. [Ecotec] stock used supercharger ?
    By SMG_07 in forum V6 Development And Modification
    Last Post: 27-03-2010, 10:37 AM
  3. Top mount supercharger idea
    By Pav in forum V8 Development and Modification
    Last Post: 06-11-2008, 06:44 PM
  4. top mount supercharger
    By shanhsv in forum Yella Terra
    Last Post: 13-08-2008, 04:25 PM
