Results 1 to 9 of 9
Thread: high ratio roller rockers 304ci 5l
    vt equipe, vt exec, 97 wrx LE
    Sep 2008
    adelaide
    Cool high ratio roller rockers 304ci 5l
    hi,
    im not sure if this has been covered, search thread did not turn up anything. i heard on the grape vine yellaterra now have higher ratio roller rockers to fit say a vp ss 5l manual? can you confirm and a price with expected gainz?
    thank you
    dirt drifter's Avatar
    dirt drifter is offline white trash hillbillie
    VS 5L M5 VS 6L M6
    Apr 2009
    massive hole in the ground
    yes they make them in 1.72 ratio (stock is 1.65) price is probably not much less than a grand for adjustable
    Quote Originally Posted by UFO View Post
    worked v8 + supercharger + dogbox = panty moistening equipment.
    4 banger turbos with bov's will just cry when they hear it, because they can never have it.
    Quote Originally Posted by GRPABT1 View Post
    Avoid cluey police
    VZ COMMO STOCK
    Feb 2007
    MELBOURNE
    VS SS 5L
    Oct 2008
    VZ COMMO STOCK
    Feb 2007
    MELBOURNE
    Done ,
    Ive PM'ed you just now.
    For a hydraulic cam setup, (standard) a non adjustable is normally used, if a big hydraulic or a small solid is going to be used an adjustable rocker arm is sometimes easier to setup for a big hydraulic and a must for solid.
    Mike
    YT
    XR8
    May 2008
    VS GTS & VT XU6
    May 2011
    is there any plans for a higher ratio or not posible ? i know it would be small but has there been any before and after power increases measured ?
    VS GTS & VT XU6
    May 2011
    VB SL/E
    Dec 2008
    Do they fit under the standard injected covers?
  1. high ratio roller rockers or cam?
    By HuskeyVR in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 13-03-2011, 02:04 PM
  2. [VIC] WTB: High Ratio Roller Rockers for VR V6
    By matt089 in forum Swap / Wanted to Buy / Trade
    Last Post: 30-09-2009, 05:20 PM
  3. High Ratio Roller Rockers
    By VSSECO in forum V6 Development And Modification
    Last Post: 20-03-2008, 11:18 AM
  4. High ratio roller rockers
    By blaze in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 13-11-2006, 11:35 PM
  5. High Ratio Roller Rockers
    By Griggsy in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 28-12-2003, 10:11 PM
