Results 1 to 5 of 5
Thread: V6 Platinum Adjustable Rocker Mounts
    Jul 2004
    Default V6 Platinum Adjustable Rocker Mounts
    Hi there,
    I have a set of 1.65 YT Platinum rockers on my vp v6 i purchased 2nd hand. I was wondering do you sell a different/stronger rocker mount for these rockers or could i even use studs with them? They are a 3/8" bolt version. I have another v6 motor with the same rockers but 7/16 bolts and much better/stronger mounts, compared to the ones these rockers have (see pic below). My rocker to valve tip contact patch is abit off center so was going shim it to get it spot on but if i could supply you with the correct mount height could you supply either better mounts or studs?
    Cheers dan
    Attached Images Attached Images
    Jul 2004
    VZ COMMO STOCK
    Feb 2007
    MELBOURNE
    so the rockers you have are 3/8 mounting???
    if so they should have 13.60mm pedestals,if correct unfortunately i dont have any other heights available as the V6 VN-VP was the only head to use the 3/8 mountings.
    i would recommend using shims but being careful not to go too high that the bolts become too short
    Mike
    YT
    Jul 2004
    Yeah they are 3/8" bolts. The pedestals with these rockers are 19mm with 1.5mm washer underneath. The other set have a totally different pedestal much bulkier and stronger looking as you can see in the picture. Remember these are quite a few years old now they haven't made adjustable for a long time but was wondering if you still have or could make pedestals like the pic below?
    VZ COMMO STOCK
    Feb 2007
    MELBOURNE
    yep, i still have the ones in your picture, but only to suit a 7/16 bolt, nothing in 3/8 or 5/16 , only the platinums rockers use the bulky hardware now.
    Mike
  1. PLATINUM GOLD VN Calais
    By YURNXT in forum VN - VP - VG - VQ
    Last Post: 03-10-2011, 07:57 AM
  2. platinum spark plugs
    By MrWooFarkinHoo in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 25-04-2010, 05:19 PM
  3. 304 will i need adjustable rocker arms ?
    By v8commy in forum V8 Development and Modification
    Last Post: 03-02-2010, 10:03 AM
  4. NGK laser platinum
    By CANYONERO in forum LSx Development and Modification
    Last Post: 13-08-2008, 04:42 PM
  5. platinum sparkplugs
    By harry3 in forum VL Holden Commodore (1986 - 1988)
    Last Post: 01-01-2008, 08:49 AM
