Results 1 to 5 of 5
Thread: 304 roller rockers
    vr ss
    Jul 2011
    New Zealand
    Default 304 roller rockers
    What different options are available I'm
    Looking at installing a fast street cam in my vr auto and wondering what's available and what benefits there are to using roller rockers
    Munz's Avatar
    Munz is offline Right Foot Action
    VZ Calais LS1 / VL RB30e daily
    Jan 2011
    Brisbane NTH
    From YT website it was pretty hard to find...j/k
    Why Choose Roller Rockers?
    Greater strength
    roller rocker ratio
    The rocker arms used on Yella Terra and Street Terra roller rockers are infinitely stronger than standard pressed steel arms providing the best in resistance to bending and breakage under high spring pressures at high RPM's.
    Pressed steel rocker arms, in high performance applications, are prone to failure, A high rate of fulcrum wear, flexing, cracking, splitting and breakage are common problems that will result in power loss or possible piston failure due to detonation of the incoming air/fuel charge. Other Yella Terra rocker components such as the trunnions, posi locks and bearings greatly enhance valve train durability in performance applications.
    Reduced valve guide and seat wear
    The traditional metal tip on standard rockers literally drags across the valve tip as the rocker opens and closes causing high side loading on the valve. This inside force leads to irregular and rapid valve, valve guide and valve seat wear in many engines. The roller tip on Yella Terra and Street Terra roller rockers eliminates this side loading action, as a result engines rev quicker and freer with a crisper exhaust note and maintain peak efficiency longer.
    More power through less friction
    The use of needle roller bearings at the rocker fulcurm combined with roller tip at the valve greatly reduces horsepower robbing friction in the valve train to provide a measurable power increase over standard rocker systems.
    Reduced heat
    The reduction in friction with roller rockers has additional benefits of reducing the operating temperature and foaming effect of engine oil to provide a cooler running engine.
    Valve train adjustment
    Use of high performance hydraulic or mechanical camshafts requires some form of valve train length adjustment to achieve correct clearance and geometry. Adjustable roller rockers allow these corrections to be made quickly and easily.
    Valve train stability
    Yella Terra and Street Terra "Easy Fit" shaft and pedestal designs offer the most rigid rocker system without using restraining devices such as guide plates, screw in studs and stud girdles. The result is more consistent valve lift and vastly improved valve train reliability at substantially lower cost.
    Reaper's Avatar
    Reaper is offline Tells it like it is.
    E3 Senator Manual, VP SS
    Aug 2004
    How big is the cam and how many revs do you intend to pull?
    Reaper
    Reapers Black VP SS
    0-60 mph = 5.39 Sec, 2.30 60'
    Quote Originally Posted by skruba View Post
    practice makes perfect dude i was (still am) my bros guinea pig,he has been tattooing for near 2 years.
    vr ss
    Jul 2011
    New Zealand
    Default decisions
    Im currently thinking the crow 4502 as a cam new valves and springs etc have standard inlet manifold larger throttle body otr cold air intake and pacemakers and twin 2 1/4 exhaust I have a couple of memcals here but will properly have to get another done
    vr ss
    Jul 2011
    New Zealand
    Can I please get a recommendation and price or idea please
  1. [VIC] Wtb or swap: 1.7 roller rockers for my 1.8 roller rockers for ls1
    By grantlyy in forum Swap / Wanted to Buy / Trade
    Last Post: 20-07-2011, 04:07 PM
  2. will 308 roller rockers fit 304 ?
    By SRH-420 in forum V8 Development and Modification
    Last Post: 06-08-2010, 03:50 PM
  3. 202 Roller Rockers
    By jakbob in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 23-12-2009, 08:05 AM
  4. roller rockers/cam
    By PUSHIN in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 25-08-2009, 03:09 AM
  5. roller rockers
    By tysonsvyss in forum VY Holden Commodore (2002 - 2004)
    Last Post: 18-01-2007, 10:44 PM
