| Yella Terra Performance and Supercharger Specialists - www.yellaterra.com.au |
05-02-2007, 02:14 PM
Ride: VN Calais 5.0, UC Torana L67, WB Ute EFI 5.0
Hey Dave, my M90 is off being HPC coated as we speak. I will show a pic once i get it back hopefully later this week!
05-02-2007, 03:40 PM
Ride: VT super6
Quote:
Originally Posted by krazyboris
Im already running a factory fit m90, just curious how easy it is to upgrade to the "push-on" 10psi pulley (with the tool on the webbie as well of course).
Also, does it come with a revised belt?
and finally, if you could give me some prices on these, that would be great:-
10psi push-on pulley
Pulley change tool
revised belt
Thanks guys.
P.S, I was recommended to you guys buy my uncle, who around 20 years ago was using your products, hows that for keeping it in the family!
Ha ha yeah I probably sold the stuff to him.
Press on pulleys are $120.00
Removal install tool $200.00 with $150.00 back when it's returned.
Shorter belt to suit $41.50.
Cheers.
Mark.
05-02-2007, 06:32 PM
Ride: VYII Spac S/C
nice.......def' in my price range. Thanks heaps guys
__________________
Quote:
Originally Posted by Not_An_Abba_Fan
Now if the poll was 'Would you let someone else root your missus' then the answer would be different. That would depend on what their missus looked like and if you could root them.
08-02-2007, 12:16 AM
TUFF 6
Ride: VT Calais S1 L67 A4
When using the YT tool, the standard pulley is a sinch to get off!!! It's even easier to get the YT pulley on.
Tark
08-02-2007, 08:27 AM
Ride: VYII Spac S/C
Excellent to hear! Decided to wait on getting the pulley till I can afford the rockers at the same time, but shouldnt be more than a year all up. On the note of the rockers, will I need a differant gasket for the rocker cover, or will a new GM one be fine?
__________________
08-02-2007, 02:37 PM
Ride: VT super6
Standard GM "O"ring gasket is fine if you even need that, they are often OK to re-use.
09-02-2007, 12:41 PM
Quote:
Originally Posted by AirStrike
I would rather run with part of the blower out of the bonnet and have the cooling power of the TT then have it under.
Have you with either the Whipple's or M90/112's tried HPC coating them at all?
I'm slowly piecing all this together looking at the Whipple on a low comp 355.
Here you go Dave (and anyone else who is interested), here is a couple of pics of my M90 back from being HPC coated and assembled back up.
09-02-2007, 03:55 PM
Ride: VYII Spac S/C
mmmmm....very nice...very nice.
__________________
14-02-2007, 05:29 PM
Ride: VP SS,VP Exec,Gsx-R 750
Hey
Im currently running a standard VP 5ltr and am looking at one of these kits. I have fitted a set of Gilmer pulleys to the engine, with a P/S pulley that bolts to the front of the Gilmer Crank pulley. Is this compatible with the belt drive on the S/Charger, or would I need to revert back to the standard pulley system? The car is also running Pacemakers with a 2.5 inch straight through system, is this adequate, or is 3 inch recommended?
Can you also recommend a Camshaft that would compliment the addition of the S/Charger? I have access to camshafts at good prices through work contacts, or can get one custom made quite cheap.
Thanks
15-02-2007, 07:46 AM
Ride: VT super6
The blower drive belt runs in front of the standard belts so if your gilmer system is no further out than standard it should work OK.
A rough rule of thumb is the less restriction the better with superchargers exhausts so 3" would be better than 2 1/2".
We have a custom cam grind we have been getting Crow to do for the blown V8's. If you contact our sales office the guys can give you the specs.
Cheers.
Mark.
15-02-2007, 04:52 PM
Thanks for the reply.
The Gilmer itself is fine, its just the fact that I have a P/S pulley bolted to the front of it, and have had to bring the P/S Pump forward about an inch to get the pulleys to run inline. Thats where I am wondering if I may have trouble?
Also, how loud are the Superchargers? If I had to get rid of the Gilmers for it to work, would I still get a Gilmer-style whine, or are they quiet when running?
One last thing, if you were fitting this kit to your car, what else would you do? You have already mentioned 3 inch exhaust, bigger throttle body and Cam swap, anything else besides all that and most likely a Dyno Tune?
Thanks
19-02-2007, 03:05 PM
I see STUPID people.....
Ride: e30 318i manual
How much and what do i need to strap a charger to my stock l36 Ecotec?
__________________
My Ride:
e30 318i BMW
Mods:
Lowered with King Springs and Bilstein Shocks
Cannon "Argh"
Racing Seats
Shadow Headlights with Halo's
17's
20-02-2007, 09:02 PM
YT Air Induction
Ride: VP V6 Commo/VL Belina 5.0
Quote:
Originally Posted by Jesterarts
