The pre-ecotec or series 1 engine came out in the USA and Canada with an M62 eaton supercharger, and I think that engine code was also L67.
The M90 is too wide to fit that manifold from memory cos the injectors were mounted in the manifold not the heads like our L67 series 2 engines. I think the way CRS do thier kits is about the most sensible for the early V6's, maybe we should see if they want to use the Terrachargers on some, cos is the same size as M90.
Cheers.
Mark.
