| Yella Terra Performance and Supercharger Specialists - www.yellaterra.com.au |
05-02-2007, 10:57 AM
If it aint blown it sucks
Ride: Supercharged 97 VS Calais
Many Many Questions
Hey guys I have a few questions about Y/T products as I am keen to start throwing some at my s/c vs calais.
1. How much are Yella Terra's 1.9:1 roller rockers.
2. Is there a whipple conversion kit available for the L67, and if so, is it worth doing and what price is it?
3. What water to air intercooling options are available from Yella Terra and at what prices?
__________________
* Yella Terra 10psi Stealth pulley
* NGK BPR6-EF 1 range colder spark plugs gapped to 1.0mm
* 82 deg C thermostat
* Twin cat 2.25" into 3" exhaust
* 3.9:1 LSD, speedo corrected
* 17" wheels with 235/45 Kumho Ecsta KU31's
* Lowered springs
* Blue LED dash & interior illumination
* Sony MP3 head unit, JL Audio splits, monoblock and sub
* Best 1/4 ET - 14.581, 2.003 sec 60 foot time recorded with badly slipping auto. Fully rebuilt with billet servos and stage 2 shift kit coming soon!
05-02-2007, 11:36 AM
Ride: MY08 Outlander XLS
I did a set of Yella Terra Street Terra rockers but they were only 1.8's $740.
05-02-2007, 02:04 PM
Ride: VT super6
1. The newer style Ultra Lite rockers are $697 set inc push rods and mounting hardware.
2. It is in production, price not finalized as yet but expect $5,500 - $6,000
3. We have a stealth cooler kit 25mm thick $1980.00 and the Tower of Terra cooler kit 57mm high $2980.00 and we are working on an intermediate cooler about 32mm high to replace the TT, as there can be clearance issues with the TT.
Cheers.
Mark.
05-02-2007, 04:39 PM
Thanks Mark!
what benefits are there to the whipple conversion?
__________________
* Lowered springs
05-02-2007, 04:53 PM
Ride: VT super6
Far greater power potential.
The M90 is big enough to supply air for about 450 hp
The W140 can supply enough air for about 750 hp
First car we fitted one on is making 402 RWHP 299 RWKW
Cheers.
Mark.
05-02-2007, 05:04 PM
What other modifications has it got to be making that kind of power?
__________________
* Lowered springs
05-02-2007, 05:11 PM
Ride: VT super6
It's a hamburger with the lot.
Forged pistons, ported heads, mild cam, roller rockers, custom pipes, CAI etc.
06-02-2007, 07:58 PM
Ride: VYII Spac S/C
I have a question, are the pushrods included in the 1:9's available in 5/16"s?
I have a series 2 VY, and apparently the standard pushrods do not work correctly, not allowing for enough clearance. Thanks in advance.
__________________
Quote:
Originally Posted by Not_An_Abba_Fan
Now if the poll was 'Would you let someone else root your missus' then the answer would be different. That would depend on what their missus looked like and if you could root them.
06-02-2007, 08:17 PM
Ride: VN Calais 5.0, UC Torana L67, WB Ute EFI 5.0
You would be talking about those "other" rockers, the YT rockers have no such dramas at all. I run 1.95/1.84 spilt ratio YT ultralite rockers with the YT supplied pushrods with no problems at all!
06-02-2007, 08:52 PM
Ride: VYII Spac S/C
Im sorry, bit of a n00b question, but what exactly are/is split ratio?
__________________
06-02-2007, 08:56 PM
Split ratio means, i'm running 1.84 on the inlet valves & 1.95 on the exhaust valves. YT have found that the split ratio is good for keeping the nasty detonation away and also yields good power gains aswell.
06-02-2007, 10:31 PM
Ride: VYII Spac S/C
Thanks for the info
__________________
