| Yella Terra Performance and Supercharger Specialists - www.yellaterra.com.au |
09-02-2007, 01:45 PM
crappy ol' VN driver
Ride: VN3.8 5spd/VSII3.8/VH5.0
308 heads
whats the best heads for a 308, haven't decided yet if i'm going to stay pre efi or use the later efi style heads as they don't have siamesed exhaust ports(and the hot spot that would go with that). i'm currently running a 4bbl TB injection setup with brocky 'B' cast heads.
cheers
Bart.
p.s. do you have flow figures for these heads etc
__________________
Body by Holden, Soul by Brock the Legend will live forever
09-02-2007, 01:49 PM
Ride: VN Calais 5.0, UC Torana L67, WB Ute EFI 5.0
For a pre-efi 308, you cant go past the dash 3 alloy heads, but thats if you have the dollars to go alloys! For efi, the VN efi heads are pretty good from the factory with some good port work, or if you have the dollars go with the dash 9 alloys!
09-02-2007, 03:51 PM
Ride: VT super6
The EFI heads have a higher port angle so they flow better with the same size port cross section. Don't compare port cc's though, cos they are a much shorter runner than the carb version.
A lot of people are staying with the early model heads these days and getting good numbers out of them with the Torque Power range of manifolds.
09-02-2007, 04:20 PM
<---------Aint it true!
Ride: 91' VN SS & 94' VR BT1
Keep in mind if you change to EFI you also need to change the cam to suit along with having injector bosses drilled in the manifold.
__________________
function > form
10-02-2007, 11:04 AM
Quote:
i'm already running EFI through a throttle body injection setup so it's not difficult to change over, when i decide which heads i'll use then i'll get a cam to suit. i was considering keeping the 'B' cast heads now as it's a brocky modified commodore and i'd rather keep it reasonably stock, maybe a good port and polish to start with, solid cam, scat rods, forged pistons, original crank cryogenicly treated so it can pull decent revs etc i know i should be able to get 400hp with these heads with original stroke etc, then i've got a BIG NOS kit to go on top of that so 700hp total with nos is the target
__________________
11-02-2007, 07:46 PM
Quote:
Reasonably stock???? If you do all that to the motor all that is left of the Brock engine is block heads & crank. Please tell me you are not doing this to an original Brock engine?!?!
11-02-2007, 08:31 PM
Quote:
unfortunalty it's not one of the 500 he built each year for homoligation purposes, if it was then i wouldn't do that much with it. it's an HDT modified commodore, someone purchased it as an SLE and then HDT modified it. i'll keep the original rods/pistons so i can always revert it back to original.
__________________
| Thread Tools |
| Display Modes |
Linear Mode
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is Off
| Thread |
Thread Starter |
Forum |
Replies |
Last Post |
VN V6 heads
Bz Kn33z |
VN - VP Holden Commodore (1988 - 1993) |
0 |
05-12-2007 04:29 PM |
304 Heads
VSL05L |
VR - VS Holden Commodore (1993 - 1997) |
2 |
27-02-2007 09:05 AM |
Which Heads?
Lexx |
V8 Development and Modification |
13 |
26-08-2006 12:13 PM |
hay rev heads
pookie_1 |
2 |
29-10-2005 04:08 PM |
202 heads
bommodore |
VB - VK Holden Commodore (1978 - 1985) |
6 |
28-09-2005 10:28 PM |
Loans | Internet Advertising | Loans | Restaurant Offers | Loans | Car Reviews
