Page 1 of 3 123 LastLast
Results 1 to 25 of 60
Thread: 1.95 Hi ratio rockers part#
    Aug 2004
    Default 1.95 Hi ratio rockers part#
    Have seen your 1.9(YT6651) rockers but can't find your 1.95's anywhere??
    do you have a part number/price for them to suit 1998 vt v6
    cheers
    VT super6
    May 2006
    Aug 2004
    is there much difference between 1.9 to 1.95 as far as better performance?
    HoldenManDan's Avatar
    HoldenManDan is offline Built, not bought...
    VS Exec SII 4.2L L67 T56 :D
    Jul 2006
    Penrith, NSW
    *BUMP*
    I'm also wanting to know, even improvements over stock would be good. Do you have any dyno sheets from a VS before and after?
    Thanks
    VT super6
    May 2006
    Power gains from increasing the rocker ratio varies a lot, usually between 10 and 25kw. NA engines tend to see less gains than SC and modified engines, particularly with exhaust, t/body CAI mods. The latest test was done at Chipcontrol the other day so I will post up figures when they come through.
    Cheers.
    Mark.
    VT super6
    May 2006
    Quote Originally Posted by dagsy View Post
    Very little, usually 2 or 3 kw. but we have seen good gains by using mixed ratios particularly on high boost supercharged engines.
    VS CALAIS's Avatar
    VS CALAIS is offline S/C CALAIS
    VS S/C Calais
    Jun 2005
    MELBOURNE
    what "Mixed ratio" would you recommend for a L67 running 10psi ?? just thought i asked before ordering
    SUPERCHARGED V6 VS CALAIS
    R.I.P Peter Brock 05 The Man The Legend
    VXII 02 Berlina
    Mar 2007
    Will i have any problems fitting these to my VXII V6?
    VZ COMMO STOCK
    Feb 2007
    MELBOURNE
    Default Mixed Ratio
    Quote Originally Posted by VS CALAIS View Post
    We normally recommend 1.9 inlet,1.95 exhaust.
    Cheer's Micky.D
    VZ COMMO STOCK
    Feb 2007
    MELBOURNE
    Quote Originally Posted by swn081 View Post
    They will bolt on quite nicely with a standard camshaft.
    VXII 02 Berlina
    Mar 2007
    Quote Originally Posted by MICKY.D View Post
    excellent
    CNULTR's Avatar
    CNULTR is offline SLEEP3r
    VY 25th Anniversary II
    Sep 2005
    I got a VY series II i was just wondering would it make ticking noise in the engine bay if i put the 1:95rockers and pushrods??
    VT super6
    May 2006
    No.
    That problem seems to be limited to modified factory arms.
    We have plenty of VY II's running the full rollers with no noise.
    CNULTR's Avatar
    Sep 2005
  15. #15
    VT super6
    May 2006
    Standard factory rockers that have been welded up and re-machined to change the ratio.
  16. #16
    VS CALAIS's Avatar
    VS S/C Calais
    Jun 2005
    MELBOURNE
    Cheer's Micky.D
    Thanks Micky for the info
  17. #17
    VT Exectutive
    Feb 2006
    Default 1-95-1 rockers
    Hi, I'm interested in the 95 rockers and am curious on what I could expect at the rear wheels power and torque wise - best and worst case. I have the usual mods - CAI = K&N filter - headers and 2.5inch exhaust with tune - made 170rwhp on a hot day. What could I expect from the rockes? Appreciate feedback = cheers
  18. #18
    VY S SII s/c V6
    May 2006
    Quote Originally Posted by TappetHead View Post
    No.
    Mine's a VY II - YT roller rockers fitted -no probs here
  19. #19
    VS Calais & vh sl
    Dec 2006
    deception bay
  20. #20
    VT super6
    May 2006
    Quote Originally Posted by 180sc View Post
    HOw do the split ratio rockers affect valve and guide wear?
    All roller tipped rockers reduce the valve guide wear provided they are set up properly (correct geometry). Higher ratio rockers mean the valve is opening further and faster but the advantages of the roller tip far outweigh the dissadvantages of the extra movement.
    cheers.
    Mark.
  21. #21
    HSV VZ LS2 Senator
    Jun 2006
    Sydney/NSW
    My last upgrade was from YT 1.8stealth rockers to 1.9in/1.95exh Split ratio (works better with the supercharged engine) and you could notice the difference straight away and I already had 185+rwkw combo.
    Haven't had it dynoed yet since the upgrade but seat of the pants feel was noticable.
    Cheers col.
    Attached Images Attached Images
    HSV VZ LS2 Senator, Stealth2 cam 307rwkw.http://forums.justcommodores.com.au/...ados-blue.html
    VS11 Berlina L67 super6 wagon 196rwkw. http://forums.justcommodores.com.au/...ified-cai.html
  22. #22
    silver_bullet's Avatar
    silver_bullet is offline Now Genesis Blue Bullet
    vr commodore S
    Jul 2005
    moura
    whats involved in installing these, pull off old head put on new. do they come pre assembled. no major adjustments. no new tappet covers or anything in that nature.
  23. #23
    VT super6
    May 2006
    Quote Originally Posted by silver_bullet View Post
    They are a fairly straight forward bolt on.
    Everything you need is supplied in the kit except maybe valve cover gaskets.
    They are non adjustable and only need to be shimmed if you have a non standard camshaft.
    Cheers.
    Mark.
  24. #24
    vs ute
    Sep 2008
    these seem like a great little addition to modifying the v6's, but what about camshafts as these different ratio rockers are only going to be extending valve lift and speed correct?
    do you guys do any cam packages as well to get a bit more duration to help build up intake velocity?
  25. #25
    VT super6
    May 2006
    Yep.
    We have one camshaft available that is specifically designed for high boost supercharged applications but you can only use 1.6 or 1.7 rockers with it.
  1. 1.95 Hi ratio rockers
    By HoldenMan7 in forum V6 Development And Modification
    Last Post: 12-10-2008, 09:38 AM
  2. high ratio rockers
    By RabidDog_12345 in forum V6 Development And Modification
    Last Post: 27-04-2007, 10:45 PM
  3. which one...1.9 or 1.95 ratio rockers
    By dagsy in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 11-03-2007, 08:35 PM
  4. High ratio rockers low end power???
    By spice weasel (BAM) in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 03-01-2007, 01:30 PM
  5. Ratio Rockers or Cam for L67 ??
    By VS CALAIS in forum V6 Development And Modification
    Last Post: 21-08-2006, 08:13 AM
