Results 1 to 10 of 10
Thread: L67 Press on pulleys and pulley tool
    The_Monk's Avatar
    The_Monk is offline [DFCTVE]
    VR Calais/Vr Stato/80 Series Cruiser
    Feb 2007
    Scumbury, Victoria
    Default L67 Press on pulleys and pulley tool
    I was wondering where i can buy both the pulley and the pulley tool
    Also how does the tool help in fitting the pulley?
    From what i can see its a remover, unless im crazy.
    Also where would i be able to buy a stage 1 water to air cooler kit?
    Do not listen to anything this man says, they are insane illogical thoughts propagated by us, the voices in his head.
    VT super6
    May 2006
    It works as both remover and installer. theres a threaded hole in the shaft on the factory blower snout and the main bolt part of the puller tool has a stud in the end to match.
    We have no stock of puller tools at the moment though. Best bet is to find someone who has got one and can fit the pulley for you. The pulleys you can get from any place that sells YT gear: Repco, Autobarn, speed shops etc.
    Mark.
    The_Monk's Avatar
    Feb 2007
    Scumbury, Victoria
    Thanks for that, ordered one.
    I might just pull the snout off and press it on.
    VY Ex-cop
    Mar 2006
    Quote Originally Posted by The_Monk View Post
    press it on?? you'll end up stuffing ya blower, thats why they are threaded on the inside so it can be pulled on, not pressed.
    and why dont you just make a puller, cheaper.
    if ya puller you get wont push it back on, get a long bolt and washer and nut and build a pusher, cost ya a couple bucks.
    VT super6
    May 2006
    Once the snout is off the pulleys can be done on a bearing press.
    You need to support it at the end of the shaft when pressing the new one on, not the gearcase or you'll end up pressing the bearings out like TheIceman said.
    Cheers.
    Mark.
    The_Monk's Avatar
    Feb 2007
    Scumbury, Victoria
    made up a fitting tool.
    One last question.
    Do i need to change the belt or will the tensioner take up the slack?
    Boonz's Avatar
    Boonz is offline the holden mechanic
    green 355 VG ute , silver vx s pac L67
    Jul 2005
    berri, south australia
    the tensioner has heaps of movement each way, it wont hold the belt as tight but it will still be plenty to keep it in its correct alignment with the pulleys
    VY SII HBD Calais L67
    Dec 2006
    6PK-1740 is the go for the 87mm press on pulley if you don't change to a larger idler pulley as well.
    The_Monk's Avatar
    Feb 2007
    Scumbury, Victoria
    having so trouble with removing the pulley, tried a generic remover, bent the lip on the pulley and it didnt budge.
    Was going to just pull off the snout and press it off but according to the spare parts man, you cant buy a gasket for snout to supercharger.
    When do you expect to have stock on pulley removers?
    Dec 2006
    The snout to charger doesn't use a gasket. It is an alloy machined face that uses silastic, something heat and oil proof. I used Threebond and never had any probs.
    Mate, I noticed you live in Scumbury (Sunbury?). Have u heard of Chip Control? They are the YT reps on this side of town and helped me out the other day with a pulley swap for a mate. Can't recommend them enough.
    9740 3363, ask for Scott.
    He has various pullers and I think he still has the YT press tool there too. Doesn't cost that much.
    If you do remove the snout (gotta be crazy with CC round the corner), don't use too much silastic when sealing it up. It goes into the rotor cavity and stuffs the rotors up.
    Good luck
  1. press remote once driver door up press again back down wtf
    By jarred193 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 23-04-2007, 10:35 AM
  2. Pulley Tool for Super 6 in Brissy
    By Sweetas_VT_SS in forum General Discussion
    Last Post: 10-04-2007, 08:48 PM
  3. Eaton M90 Pulley Removal Tool
    By shaggerz in forum General
    Last Post: 18-09-2006, 07:08 AM
  4. 'Press Remote' ?
    By Swift in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 08-07-2006, 11:01 PM
