+ Reply to Thread
Results 1 to 11 of 11
Thread: 1.95 rocker bolt tension
    2007 VE Clubsport
    Nov 2003
    South Perth, WA
    Default 1.95 rocker bolt tension
    hey everyone
    just wondering if anyone can tell me the recommended torque setting for the rocker bolts??
    cheers
    ryan
    Check out my ride here...E Series Chubby
    VY SII HBD Calais L67
    Dec 2006
    2007 VE Clubsport
    Nov 2003
    South Perth, WA
    Dec 2006
    Remember to put the piston at TDC on each cylinder b4 doing final torque down. This position has the least load on the valve spring so you can get a more accurate torque reading and hold the rocker square to the valve stem tip because they go off centre as the bolt tightens.
    2007 VE Clubsport
    Nov 2003
    South Perth, WA
    Dec 2006
    Remove the spark plugs, turn the balancer by the bolt with a shifter clockwise because this is the normal operating direction of the motor. It is quite easy to rotate once the plugs are out. TDC is when both valves are shut, that is the main thing because then the springs are relaxed as much as they can be and the torque reading is better.
    Don't worry, nothing will stuff up when you go to start it again because the CAS and CAm sens will work out where piston 1 is to fire it up again
    2007 VE Clubsport
    Nov 2003
    South Perth, WA
    yeh guna say coz wen i did it the first time it was all gud...really i just wana make ure they are all lined up and gud the ones that arent ill adjust them
    cheers for the info mate
    ryan
    Dec 2006
    vs-6 is offline Raptorcharged VS vs-6 Executive
    VS S pac V6
    Jan 2008
    perth claremont
    how vital is the 25ft'lb and torqueing them correctly when i did mine i jsut tightened them up and that was it didnt have a torque wrench to use they are now making a ticking noice is this why?
    vn calais, vs clubsport #137
    Jun 2005
    VZ COMMO STOCK
    Feb 2007
    MELBOURNE
    Quote Originally Posted by vn calais manual View Post
    u need the correct tension to set the correct lifter preload.
    Thats correct,
    also over tightening can cause the pedestal to be squished down giving you too much
    Quote Originally Posted by vs-6 View Post
    how vital is the 25ft'lb and torqueing them correctly when i did mine i just tightened them up and that was it didnt have a torque wrench to use they are now making a ticking noice is this why?
    It would be worth taking off your covers and having a go at backing them off and torque them up to 25ft, it may fix your noise if they are loose.
    Micky.D
    YT
+ Reply to Thread
  1. Head tension
    By sik sv in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 05-06-2006, 12:39 PM
  2. high tension leads
    By chevy_big_block_bro in forum Electrical Wiring / Questions
    Last Post: 30-09-2005, 01:16 PM
  3. air bag and seatbelt tension light
    By brucef in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 27-09-2005, 06:11 PM
  4. tension pulley replace
    By k191350 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 09-09-2005, 10:46 AM
  5. tension
    By sick vs in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 07-08-2005, 05:06 PM
