yella terra pistons and rods?
hey guys just heard about the yella terra pistons and rods you've got for the ecotec.. just wondering if there is any info on them? im looking into rebuilding my ecotec as an n/a beast haha. i was after a set of pistons, rods, big end bearings (if needed) and rings that would go straight in without boring out the cylinders and that would up the compression a lot. Also i will be shaving the heads if need be. ps.. everything else on my motor is done so only need to know about this stuff.
so basically can i put pistons and rods in to up the compression without boring the cylinders? and with high compression what other things or problems will accure? thanks very much any info aprechiated\
