Results 1 to 6 of 6
Thread: ls1 roller rockers
    VX SS M6
    Jun 2008
    Default ls1 roller rockers
    I want to get some 1.8 ratio roller rockers for my vx ss. I have been told that i need to get some heat treated push rods, the reason was something about the guide plates rubbing, is this ture? Also does the length of the pushrods need to change with different ratio rockers?
    VT super6
    May 2006
    Only the Crane rockers use guide plates on LS1's.
    If you go for ours, you can use standard, or aftermarket push rods in standard length.
    VX SS M6
    Jun 2008
    yeah there prw ones i got them today off a mate who has changed his mind about putting them in and wants a cam. I know there not your ones just hoping u could help me out. I need to now wat length pushrod i need and how to set them up with clearance for the lifters and so on. any help be greatly appreciated. thank you
    VT super6
    May 2006
    As a rule, most roller rockers are made to suit standard length push rods wherever possible. I'm not familiar with PRW so all I can suggest is fit up one pair and measure the lifter crush (pre-load). If they are stud mount adjustable then you just set them to 3/4 to 1 full turn past the zero lash point. make sure you are on TDC for each cylinder you set.
    Cheers.
    Mark.
    VX SS M6
    Jun 2008
    kool. thanx alot for your help. if i get time this wekend ill start on it. let you know how it goes.
    VX SS M6
    Jun 2008
    Finished putting in the rockers, push rods and valve springs this week. I ended up having to buy yella terra rocker cover spacers, which are a great product come with every thing i needed to do the job. Car has more power and even sounds betta. Getting it tuned on monday cant wait.
  1. roller rockers
    By [JUDGE] in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 14-03-2007, 06:24 PM
  2. roller rockers???
    By vt_on_20s in forum General
    Last Post: 13-03-2007, 09:57 PM
  3. roller rockers
    By blackgen3 in forum LSx Development and Modification
    Last Post: 29-01-2007, 04:11 PM
  4. what do roller rockers do ?
    By itchy pits in forum V6 Development And Modification
    Last Post: 30-10-2005, 06:31 PM
  5. roller rockers on vt
    By chevy_big_block_bro in forum V6 Development And Modification
    Last Post: 11-10-2005, 12:36 PM
