biulding a new engine. Work being done by dandy engine's
starting with a stoker kit 4.2 steel crank and rod's. intens stage 4 blower cam worked heads and have been cnc by YT. whipple 2300 blower by from YT. 1"78 pipes. twim 3" exhaust. bigger and better intercooler than before from YT. roller rockers YT. elec water pump. twin fuel pumps bosch 440. new brain from motec . and being dyno by dandy engine's Driveline. close ratio 6 speed box and 3.9 diff gear from mal wood once engine has been built i'll list evey mod as it will be upto dandy engine's on whats done
This is going to be a top combo Ronnie.
Can't waqit to see the end result.
You really don't do things by halves.![]()
well after talking to lou yesterday when i drop the parts off. Hmmm his sending the heads away to be rebench flowed to see if we can get a bit more out of them lots of work being done to the crank then sending it off to be polished and the rod cam and valve spings polished too. May have to upgrade the pipes too 2" man i hav'nt run the last set in. I told lou im going to run 3.9 diff gear ? he said not yet you ain't the dyno will tell us what your going to run so thats it not buying anything untill lou say's what i need he has his douts on the clutch im get with what torgue it may put out ? so i told lou do what needs to be done just do it. fuel system upto lou as well he's going to sort that out when the time comes
lol think im gonna needs some tubs for some big rubber to get this baby off the line
