Results 1 to 5 of 5
Thread: Yella Terra Terra Charger
    INDACLUB's Avatar
    INDACLUB is offline Black VX SS
    Black VX SS, White VQ 5ltr
    Apr 2008
    Default Yella Terra Terra Charger
    Hi guys, can someone tell me if there is a difference between a VT 5lt and a VS 5lt yella terra supercharger. On the website it says there is a special kit to suit a VT Hydraullic Roller Cam. I have rang a few performance shops and they have all said there is no difference. Also what do you have to do to run more than the 8psi the kit comes with.
    Thank
    You.
    Farlig's Avatar
    Farlig is offline Donating Member
    Y-Series Clubsport
    Jan 2005
    It was my impression the small m90 is already running flat out when bolted on a 5L.
    GTO
    Jan 2005
    INDACLUB,
    There are only a few minor difference between the VT 5lt sedan only (YT 4081VT) and a VS 5lt S/c kit (Yt 4081).
    1. The VT sedan (only) runs a 4 rib serpentine balancer pulley which offsets the blower pulley out 6mm. This means the balancer pulley and the blower pulley are different. (so the pulleys in the kits are different)
    2. Due to the VT being a roller cam engine, it runs a roller lifter tie down bracket in the valley which has to be slightly modified to miss the built in bypass channel under the S/c manifold.
    3. The airbox is also different in the VT, so we supply a VT-V6 top half AB to marry up to the new TB position.
    Both kits are good for over 60% gain and come complete.
    Both Kits intercooled options and pulleys to raise the boost over 10 psi
    Hope this helps
    Ring Mark, Matt or Mike at YT is probs
    INDACLUB's Avatar
    Apr 2008
    Quote Originally Posted by PONTIAC GTO View Post
    INDACLUB,
    Hope this helps
    Thanks for the info.
    Which kit would i need as i have a VS Commodore but a VT Block which has a hydraulic roller cam. But i has a VS Airbox
    VZ COMMO STOCK
    Feb 2007
    MELBOURNE
    Default YT 4081 for VS with roller cam block
    The correct kit to suit the VS is the YT 4081.
    The mod's required to fit the kit are to trim the roller lifter retaining plate that sits in the valley and fitment of a electric thermo fan, like a single 16" davis craig or twin thermo's from a VT / AU. As the standard belt driven fan blades will hit the s/c snout.
    You would also need the inline temp controller , also available from davis craig. once done the kit will fit with no issues.
    Micky.D
  1. Yella Terra Cai
    By Charg'd in forum Yella Terra
    Last Post: 23-03-2009, 01:50 PM
  2. yella terra
    By korny in forum LSx Development and Modification
    Last Post: 22-01-2008, 05:54 PM
  3. Yella Terra 1.7 RR for VR?
    By Simdog in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 15-08-2006, 12:00 AM
