Results 1 to 2 of 2
Thread: Yt 6646
    '04 VY SS 5.7 A4, '94 VR 5.0L M5
    Jan 2006
    Default Yt 6646
    Hi.
    Looking at getting a set of these non adjustables, on the YT site it says:
    "Ultralite bolt on shaft type non adjustable 1.8:1. clears standard valve covers."
    Does this apply to VY2 (I know some of the later ls1s have different covers?)
    Also, I am assuming that on a car thats only done 82k odd km, that I wont need to replace the valve springs?
    VZ COMMO STOCK
    Feb 2007
    MELBOURNE
    Hey Uber_Matt,
    The YT 6646 will fit on most models with out any clearance issues.
    I have come across a few here and there that did touch the rocker covers,
    ( a batch from GM machined lower than normal i take it )
    As a precaution we can supply our new thicker rocker cover seals.
    they fit as standard but give you more clearance from the rocker assembley.
    they retail for about $18 for the pair. id try and mount the rockers first then fit a cover back on one side then turn the engine over by hand to see if you have clearance on not, worst case is the extra $18.00 for the thicker spacers if required.
    Micky.D
