Results 1 to 2 of 2
Thread: Roller Rockers .
    Fusion's Avatar
    Fusion is offline Awww I bent my wookie !
    1982 VH SL/X, 1997 SII Calais .
    Sep 2008
    Colac Vic.
    Default Roller Rockers .
    Hi Guys , I'm thinking of getting my first set of roller rockers for a black (VK) 308 and what are the benefits of using roller rockers to the standard rockers ? Never used rollers before . so a novice on this part . Thanks
    VT super6
    May 2006
    Strength is the most common reason for fitting roller rockers but you also have the advantage of the roller tip not side loading the valve stem so the guides and seats last much longer.
    Rollers typically have a better ratio than factory pressed steel arms so power gains are common.
    Adjustability is another reason to fit them as they allow you to compensate for different valve lengths or set clearance on solid lifters.
  1. 1.98:1 roller rockers
    By 17UCK! in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 11-09-2008, 06:26 PM
  2. 3/8 roller rockers...
    By pumba in forum Yella Terra
    Last Post: 15-07-2008, 09:08 AM
  3. Roller Rockers LS1
    By minux in forum Yella Terra
    Last Post: 26-03-2007, 06:02 PM
  4. YT 5.0lt Roller Rockers
    By AirStrike in forum Yella Terra
    Last Post: 04-03-2007, 06:58 PM
