Results 1 to 2 of 2
Thread: what roller rockers should i use
    vn calais,vk calais padock basher
    Mar 2005
    Default what roller rockers should i use
    i dont know what roller rockers to use on my vn.
    the current motor is a s1 but im am building a s2 up with fairly high compression so i want sumthing thats going to help get as much hp as possible.
    tim
    VT super6
    May 2006
    YT6657 are 1.8:1 3/8" mounts and should fit straight onto an S1 engine.
    The S2 heads can be drilled and tapped to take the larger bolts so the rockers can be used on both engines if you want.
    The only thing to be carefull of is the ratio.
    As a rule the 1.8's will give best gains with standard camshaft but can be too much for use with some aftermarket camshafts.
  1. ls1 roller rockers
    By Andrewss in forum Yella Terra
    Last Post: 04-09-2008, 07:54 PM
  2. Where are my roller rockers?
    By blakeb in forum Yella Terra
    Last Post: 03-09-2008, 06:51 PM
  3. YT 5.0lt Roller Rockers
    By AirStrike in forum Yella Terra
    Last Post: 04-03-2007, 06:58 PM
  4. roller rockers
    By blackgen3 in forum LSx Development and Modification
    Last Post: 29-01-2007, 04:11 PM
  5. roller rockers
    By VNCommo in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 03-06-2006, 12:09 AM
