ok heres the siuation.. igot an ecotec engine exhaust extractors n i got a 10psi CRS supercharger im goin 2 be puttin on in the next few months. but i wanta get rockers b4 i put it on. wat kind of rockers do u recomend.. and wat springs? and how much.. once the chargers on ill get it all tuned up and ive been told u need to get springs to tune. but yeh bak 2 the rockerrs wat kind do u recomend? and a part number would be good .. people seem to say mix rats r good 4 10psi.. r they just as easy 2 install ? cheerz bro![]()
My CaR dOsNt ChErP gEaRs, It JuSt KiCkS sIdEwAyS!
meep meep!!!!!!!!!
Mixed ratio seem to work best on high boost only, 15psi + so I would suggest 1.9's all round P/N YT6651
cheers bro wat about 1.95.1s more the better?
YT6662 is the 1.95 set. You might see a cpl more HP than 1.9's and price is the same but for some reason the 1.9's are much more popular.
cheers how much r they? and wat about springs do i need 2 upgrade them due 2 ill have 2 get the car tuned 4 10psi
Direct from us they are $746.00 inc gst, there is also a crow cams valve train kit available that contains, springs, retainers and collets, cost is about $350.00. i would recommend these if you are going to give her a bit of a high rev, anything over the factory rpm limiter is recommended to have the valve train kit upgrade.
Micky.D
cheers micky.D.. so id be lookin at about $1096.. and 1.95.1rockers r the highest rat rocker yella terra makes for ecotec?
