Results 1 to 11 of 11
Thread: VY 1.8's - making funny noises
    one_and_only2004's Avatar
    one_and_only2004 is offline Turbo L98 FTW
    Z Series Thunder Utility - Turbo
    Mar 2008
    Regional NSW Australia
    Default VY 1.8's - making funny noises
    Hi, i just put in a set of 1.8 roller rockers into the ute. It idles much better, resists stalling a bit more, and tends to scream a bit harder in the higher revs - all very good.
    I did notice however that my ute sounds like it's turbocharged due to this massive whistle coming from the intake. Is it just because it's sucking more air in?
    immortality's Avatar
    VN3.8 5spd/VSII3.8/VH5.0
    Apr 2006
    Auckland NZ
    whistling normally indicated a leak in the intake somewhere. did you remove/disturb anything related to the intake when you fitted the rockers?
    Body by Holden, Soul by Brock
    the Legend will live forever
    Mar 2008
    i took the throttle body off to get into the passenger side rockers. The sound's not coming from there though, sounds like it's coming from the runners. I did take the ecotec cover off aswell, and i've been told it does make for a touch more cabin noise
    VZ Thunder - 360RWKW Turbocharged V8 - Parts by AKO Performance Tuned by BPS
    VT super6
    May 2006
    mmmmmmmmmmm
    Haven't struck that one before.
    Maybe try putting the cover back on and go for a fang.
    Farlig's Avatar
    Farlig is offline Donating Member
    Y-Series Clubsport
    Jan 2005
    there is a tiny hose that runs from throttle body and into the manifold through a gap in the runners this joins another hose in there. check that hose is joined up to the throttle body. one of the guys here in adelaide had a gas blow back and it blew that hose off, its a tough one to locate.
    VU Storm
    Jan 2006
    and it whistles when you throw your boot in too
    How to be a good Australian Citizen: Drive a Camry, Become another number in the system, Dob in all other numbers for un-numberlike behavior (no matter how slight), Base all your opinions solely on the information provided by T.T. and A.C.A., Believe everything our gracious Government Tells you to.
    Mar 2008
    Yeah i had a look at the hoses, threw the cover back on and took it for a spin. Still makes the noise - definately coming from the runners. It's not bothering me - hell i actually like the noise, i thought it must have meant that something was about to explode.
    VX Calais 01 3.8lt Ecotec
    Jul 2006
    You wouldnt like it once you do an oil test and find silica/dirt ingest which over time may damage the engine. Try and seal it...
    VY II V6
    Dec 2006
    Quote Originally Posted by Farlig View Post
    IMHO, I'd say this is your problem.. It's right under the intake manifold..
    It has happened to me before (LPG backfire) and mine was making the same noise.. It made the idle a little more lumpy as if it were cammed.. oh well..
    -Nick.
    Mar 2008
    Ok lads i checked it again and found the problem - the airbox hose wasn't completely sealed around the throttle body. Someone feels like a goose...
    On a positive note, the ute seems to have gained/reclaimed some power.
    VZ COMMO STOCK
    Feb 2007
    MELBOURNE
    Thats good to hear it was something small. easy mistake.
    Micky.D
    YT
  1. car shuddering and making noises
    By Equipe VR in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 15-02-2008, 11:02 PM
  2. vs ute noises
    By andyman in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 27-06-2006, 07:29 PM
  3. fan making weird noises
    By stocky in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 16-06-2006, 09:11 PM
  4. IRS noises
    By sixshooter in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 16-03-2006, 08:27 AM
  5. vn 5L noises
    By vn5L90 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 07-06-2005, 05:49 PM
