Results 1 to 13 of 13
Thread: fitting roller rockers
    mrtrunkmonkey is offline Mrtrunkmonkey
    VS S2 S Pack Ute
    Jan 2008
    Abbotsford, Sydney
    Default fitting roller rockers
    Just a question,
    How hard is it to fit the 1.95:1 ratio roller rockers to a VS ute?
    Has anyone had any experience?
    Does anyone know where I can get them fitted in the Sydney inner west area?
    Pat
    VZ COMMO STOCK
    Feb 2007
    MELBOURNE
    They are fairly easy, just unbolt rocker covers, unbolt factory rocker gear,remove old gear including the rocker mounting plate and pushrods.
    Fit new pushrods, then aligning plates supplied, then rockers arms with 5/16 mounting bolts and torque them to 25"lbs,they come with easy to understand instructions too. any mechanic or mechanical minded person should be able to fit them.
    Micky.D
    YT
    VS S2 S Pack Ute
    Jan 2008
    Abbotsford, Sydney
    that I can do, but it says to turn the engine to top dead centre, how do I do that?
    VR Commodore V6
    Sep 2008
    Sydney NSW
    2 ways:
    1) Use your timing marks and line the timing mark on the harmonic balancer to the big line on your block. So it's neither advanced nor retarded, or
    2) Unplug spark plug 1, earth it to the block, and hand rotate the engine until it sparks, then stop.
    VS S2 S Pack Ute
    Jan 2008
    Abbotsford, Sydney
    So call me stupid, but I'm just learning, how do you line up the harmonic balancer? just turn it by hand??
    Pat
    VR Commodore V6
    Sep 2008
    Sydney NSW
    Yeah. Get a socket to fit the big bolt, and then a knuckle bar, and you just rotate it very slowly.
    VY SII HBD Calais L67
    Dec 2006
    TDC, remove the plugs, also disconnect the battery for safety. Stick a solid plastic thing in the plug hole (BIC pen or chopstick) and as you rotate the engine by hand you will feel the piston come to the top.
    It's just so all the rockers are under the same tension when they're torqued down.
    VYII Calais L67
    VS S2 S Pack Ute
    Jan 2008
    Abbotsford, Sydney
    So this again may be sounding like a silly question, SHould I repalce the Rocker cover gasket during this install?
    Also is there any other thing that I'll need to do whilst upgrading the rockers?
    VZ COMMO STOCK
    Feb 2007
    MELBOURNE
    Default YT rocker fitment
    Hey mrtrunkmonkey,
    The rocker cover gaskets should be ok, i normally just pull them out with care.
    give the seals and the seal channel a clean with a rag and refit.
    Of corse if seals are broken you should get new ones to stop future oil leaks that will **** you off.
    The rockers are pretty much bolt on and drive
    Micky.D
    YT
    96 VS executive series II 'S pack'
    Jan 2011
    australia
    i did it and it was incredibly easy to fit them. more so than i thought. i used no instructions but i checked the manual anyway to be sure..didnt say anything about aligning to tdc, and i didnt align the engine to tdc ..would that perhaps be causing something to be loose and cause the squeeking noise i keep hearing?
    acarmody is offline Donati..Whoa Green
    VX Berlina
    Apr 2007
    Cool story bro.
    I'm sure the OP has managed to get them on in the last 2 years.
    Ronald Reagan (1986)
    MR_VX's Avatar
    MR_VX is offline Forced to be Fast
    VX S pac SII Raptorcharged
    Mar 2009
    Townsville, Qld
    Quote Originally Posted by crazybiker View Post
    2 ways:
    wow i never done this, i just ripped out the factory ones and put the new ones in, and i only done them up lighty but enought with a socket
    Check out my ride here >>>>My VX Raptor
    say NO to chev badges
    Wanted To Buy=>> Mace 12mm or 25mm Manifold spacers - VX SS Headlights - VY handbrake complete set up
    For Sale=>> vt/vx Berlina/Calais chrome window surround PM me for more details
    VZ COMMO STOCK
    Feb 2007
    MELBOURNE
    Quote Originally Posted by nalchlan View Post
    thats good to hear you found them easy to fit, the rocker arm bolts should be torqued up to 25 ft lbs, a squeeking noise is very strange indeed, i would see if you can hear if it is coming from the drivers or passenger side and retrace your steps on that side of the engine, might be something very simple thats easy to miss.
    Mike
  1. VN S1 V6 Roller Rockers
    By crazybiker in forum Yella Terra
    Last Post: 25-11-2008, 02:39 PM
  2. roller rockers in v6 3.8 VP-VS
    By jimrichards1964 in forum General
    Last Post: 23-09-2008, 10:02 PM
  3. Where are my roller rockers?
    By blakeb in forum Yella Terra
    Last Post: 03-09-2008, 06:51 PM
