i was just about to ask the samething
Can someone give me the low down of what difference yella Terra rockers do?
1.8 Ratio are is what i believe are commonly used on the Buick 3800. Mine is a 1989 S2 V6.
This is a relatively cheap thing to do.
Also are they hard to install?
any info is great thanks guys.
cake as to install lierally its just unbolting swapping then re-bolting.
Yeah we dont do burnouts, we do stationary wheel rotations, much more sophisticated.
Yeah i have herd this will reduce engine noise and become more smooth is this correct?
I know there is a lot of info in this yella terra pages but was just wondering why do you replace rockers for if you know what i mean, Performance etc.?
these rockers are a different dimension than standard and the ratio from back to front on the pivot point is altered which increases the travel of the valve.
this will in theory increase valve lift to increase power just like an aftermarket camshaft.
but the duration is not changed and the valve speeds is increased.
as in the valve still has the same amount of time to open and close as before but now it has to open further so of corse it has to do it much quicker.
i guess some long term effects could be some wear on valve seats or the valves them selves?
quite a handy little mod really and a lot easier than changing a camshaft.
but driving along would u notice em just after installation if u cant be bothered with cams
cool thanks man
no worries at all Leebo
Micky.D
YT
how much do they set u back?
they'll set u back about $700 - $800 for the 1.9:1 rollers
YT Group Buy Offer V6
Check out our group buy on V6 rockers if you are after a special price
Micky.D
YT
