pooley79
- May 3, 2012
- 15
- 0
- 0
- Location
- Australia
- SV6 Series 2 Ute
So here's an issue I've got - hope someone can help me:
This is my setup: Alpine amp (MRX-F65), Type R splits in a SV6 Series 2. Amp has signal checking on the high end inputs and uses that to turn itself on from the stock Holden IQ head unit.
We (the shop) used the high end inputs first. Everything worked perfectly except there was quite a loud pop sound when I started the car. Alpine have told the shop that they need to use the low RCA inputs and the ignition line for power to fix this issue so....
They used a LOC to convert the high output to low - straight into the RCA, ignition line for power. Everything works well, no popping ... BUT... When i turn the car off, the head unit stays on until i open the door (as it should), But the amp turns off, because it must be attached to the ignition. Also if I turn the H/U on without the ignition on, same problem, no sound until the ignition switch is on - but head unit still goes. The sound quality has dropped a bit too IMO.
Does anyone have any ideas about this? Seems im stuck. Either I have popping (which mind you i could probably live with), or I have a system that has sub quality sound due to the LOCs, and I have to deal with the above issue when i turn the car off (I really wanna listen to that last bit of the news before i open the door!)
Please help!
Please help!
