vn6pwr said:
I just have to get a bar (unless it comes with) to mount them.
Most of the driving lights kits come with the lights mounted on a metal bracket of some sort, so all it is, is just a matter of bolting them on or below your bumper bar. There is usually three types of driving lights apart from round and rectangular. One is broad beam on both lights. This is good to see the roos coming at you from the side
I prefer these because I like to see the whole road and sides lit up. The next type is pencil beam on both lights. This setup provides a much longer view than broad beam, but only on the approx width of the road. The other type is a combo set up. This is one light is broad beam and the other is pencil beam. This provides the both types in one. I think that set up wouldn't be too bad but never considered it as much as broad beam. I have had broad beam lights in the past and I find that they light up the road enough.
vn6pwr said:
Also where along should i tap into the High Beams power wire?
At one of the headlights in the engine bay, there would be a bunch of wires coming out of the headlights. One of them will be a high beam wire. Which one I don't know, but it would likely be colour coded. You could always unplug the wiring and have a mate turn on and off the high beam switch while you use a multimeter to test the voltage of the wire switching on and off. You only need one of those wires as it is basically used as a trigger like shown in my diagram in the other thread I posted. Make sure you use a switch like in my diagram because you don't want to be driving around built up areas with 200W driving lights on. They are especially best suited to places where it's dark like on country roads etc...
