Friction
- Feb 21, 2006
- 141
- 1
- 18
- Location
- Capalaba, QLD
- Looking for a new Commodore
I have done several searches and could not anything that would help me, so I hope someone can.
I have 99.99% completed a VP to VS dash conversion with the exception of getting the instrument wiring to work. I have the wipers working on Low and High speed which is fine, the lights only work on normal beam without parkers. The following switches are as follows:
AC
2 Brown wires to Brown
Green with yellow stripe to Green with yellow stripe
Black to Black
Brown with white stripe to brown with white stripe
Hazards
Black to nothing
Brown with white stripe to nothing
Purple to Purple
Blue with white stripe to blue with white stripe
2 dark blue to dark blue
2 light blue to light blue
Orange with red stripe to orange with red stripe
Nothing to white with green stripe
Rear Demister
3 Black with brown stripe to black with brown stripe
Pink with brown stripe to pink with brown stripe
Grey with Black stripe to Grey with black stripe
Black to nothing
Nothing to 2 Black with white stripe
Nothing to White
Nothing to Orange with black stripe
Now the hazard switch works fine. The blinkers indicate and the hazard light shows in the cluster.
The AC is having problems as it was before the conversion, so I don't know if it is wired up correctly.
The rear demister shows up in the cluster but I have no idea if it is actually working. I can only assume that it is.
Blinkers no longer work whereas they did before I changed the above switches to the VS ones.
So can someone who knows something about electrics or has done this conversion before tell me if I have wired the switches up correctly and how to get my blinkers working again. I can only assume that all the wires must be used on the other switches to get the blinkers working. I would really appreciate some help asap as I hate driving without the blinkers working.
AC
Black to Black
Hazards
Black to nothing
Purple to Purple
Rear Demister
Black to nothing
Nothing to White
